TRENDZ wrote:You will find that these are the easiest springs you will ever change.
PToombs wrote:I did the Moog 7226S springs in mine, and 1 side I had to use a mini chain binder to draw the spring down so I could start the nut on the ball joint stud. The other side I did with just a floor jack.
