Rear Axle Gears
Rear Axle Gears
Postby Bad93Cummins » Mon Jan 04, 2010 11:05 am
I swapped in a NV4500 from my A518 auto tranny. I notice that in 5th that 70-75 is pretty high rpm, should I keep my 3:54(I belive that's whats in my truck) or should I go down to 3:07 like how the 5 speeds come from the factory?
Its 2wd truck.
Bad93Cummins
Postby oldestof11 » Mon Jan 04, 2010 2:13 pm
rbrettctd put a G360 in his truck that had a 727 and a 3.07 and he loves it! 23mpg and keeping up with the Dmax's.
Postby Richie O » Mon Jan 04, 2010 2:22 pm
3.54's and a overdrive should not be to high of an rpm at 70. I have 4.10's in my rag truck and I can do 90 plus in high gear. I would stay away from 3.07's due to the lack of parts. They don't make the ring and pinion any more so they can be a pain to find a good used set. As far as I know 3.07's never came in a standard equipped truck, only the auto's from 89 to 91.4 ( and Philips 93 ) :D
Postby oldestof11 » Mon Jan 04, 2010 5:55 pm
Richie, available all the way to 93 in the FSM is the 3.07 gear set by special order only. At least this is what I was told.
Postby Richie O » Mon Jan 04, 2010 6:08 pm
oldestof11 wrote:Richie, available all the way to 93 in the FSM is the 3.07 gear set by special order only. At least this is what I was told.
Like I said, the only one I have ever heard of is Philips 93. I have yet to see another 91.5 up truck with 07's. :D
Postby PToombs » Mon Jan 04, 2010 6:10 pm
You say you have high RPM's, how high? 2000 is about normal for most of our trucks at 65-70 or so.
Postby Bad93Cummins » Mon Jan 04, 2010 7:41 pm
2200-2300 at roughly 70-72, was 2200-2300 at 80-82 with the auto.
Bad93Cummins
Postby Ace » Mon Jan 04, 2010 8:51 pm
There was a noticeable change to me in fuel consumption and driving comfort with just a couple hundred rpm's difference at cruise. A setup that's running around 1800 rpm at cruise (whatever speed that is) returns the best fuel mileage and a quieter, more comfortable ride. 2000rpms was just a little too buzzy for me in either the 1st Gen or the commonrail - same effect.
I have both my trucks set up with tire/gear combos to cruise 1800rpm at 70mph.
Ace
Postby Bad93Cummins » Tue Jan 05, 2010 12:06 pm
I agree with you ACE!
Bad93Cummins
Postby dpuckett » Tue Jan 05, 2010 2:53 pm
Is the speedo gear from the NV4500 set up for your gears? Sounds like the "new" tranny was from a 4.10 truck. IF you didnt change the tranny speedo gear, it will still read like it has 4.10s. In other words, when it says 70, you are really doing 80. Check it with a GPS or interstate mile markers.
I almost bought a 93 D250 with a 5spd and 3.07s, til the guy sold it out from under me for $200 more than we had agreed on. Said he got it that way from the factory. I think they were available on the 3/4 ton trucks. Probably Dodge clearing out their stock before the body style change.
DP
Postby PToombs » Tue Jan 05, 2010 6:39 pm
Yeah, better check the gears! You may still be doing 80-82 at 2200. Won't be good when the cop pulls you over! :lol:
Postby Bad93Cummins » Thu Jan 07, 2010 8:12 pm
Everthing still the same, the spedo still reads 2mph fast. So would it be worth it to change to high gears or no?
Bad93Cummins
