locker
locker
Postby stock91w350 » Wed Jan 06, 2010 5:06 pm
would my 91 w350 dually, getrag 5spd, 410gears, be a better snow plower with a locker in the rear, what are the pros and cons? thanks
stock91w350
Postby SNOOT » Wed Jan 06, 2010 5:07 pm
if you have a limited slip rear diff no..
1993 W350
SNOOT
Re: locker
Postby stock91w350 » Wed Jan 06, 2010 5:19 pm
stock91d350 wrote:would my 91 w350 dually, getrag 5spd, 410gears, be a better snow plower with a locker in the rear, what are the pros and cons? thanks
its one wheel peel, never seen it spin both rears at the same time
stock91w350
Postby ahale2772 » Wed Jan 06, 2010 6:33 pm
ive got the same issue but i most ly solved it with big rubber, 12.5 inch bfg's
Postby oldestof11 » Wed Jan 06, 2010 7:35 pm
Get a factory PowrLok, holds almost anything and I have never had a problem with them in either of my trucks.
Postby stock91w350 » Wed Jan 06, 2010 7:56 pm
oldestof11 wrote:Get a factory PowrLok, holds almost anything and I have never had a problem with them in either of my trucks.
Any idea wher i can find one?
stock91w350
Postby U.S MMA » Mon Jan 11, 2010 9:18 pm
any shop that is a dealer for dana spicer. they are a good unit, the traction is great, don't notice on the street like a locker.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
U.S MMA
