DANA 70 identifiers
DANA 70 identifiers
Postby TRENDZ » Sun Jan 10, 2010 3:03 pm
I have an early 91 cab/chassis. I want a posi diff. It has an open diff with 3.07 gears. What are my options? I've been lead to believe that the 3.07 was alone in ring gear spacing, and no posi carrier was ever factory produced for it. I've read more than once that there are two posi carriers, 4.10& down/ 4.56& up. If this is true, than the 3.07 is alone, because I had a posi out of a dana 70 with a 4.10 gear, and it didn't fit in my old truck with 3.07 gears until I put it in the lathe. Anybody have any more defined info on this?
TRENDZ
Postby Richie O » Sun Jan 10, 2010 4:03 pm
I have a 307 factory posi. They were made. I found my rear in a junkyard. They had it listed as a factory posi ( they had scraped the truck and keep good records ). We pulled the cover off and sure enough, it is. It replaced my open rear that let go. As to which carrier will fit and which one won't. No idea. I know there are guys here that have added posi's to there 3.07 setups.
Postby TRENDZ » Mon Jan 11, 2010 7:36 pm
Hmmm.... really stumped now. How do I find out if I have a dana70 or a dana70HD? I would assume that being a long wheelbase cab/chassis diesel, that it would be an HD, but it only has 32 spline axles.
TRENDZ
Postby skilletky » Mon Jan 11, 2010 9:21 pm
i have heard that a 32 spline means its a d70u. that is what mine is. someone correct me if i am wrong.
skilletky
Postby 2stroke » Tue Jan 12, 2010 6:09 am
if you have 3.07 gears then it wil be a dana 71.
91 non I/C w-350 SRW
2stroke
Postby TRENDZ » Tue Jan 12, 2010 5:12 pm
O.K. today I had a guy at work look in the chrysler parts program.And it was confirmed that you could get posi with 3.07s. For a spicer 70-71 with power-loc, there is a before/after date that is "up to 11-12-90" and "after 11-12-90". (I don't know if this is the truck build date, or the axle build date) The early date specifies the 3.07 by itself, with it's own part number (stamped 707130x) With the 3.55,4.10 sharing a part number(stamped 707073x) And then the 4.56 with it's own part number(stamped 73489x).
The later date axles list 3.07,3.55,4.10 (stamped 74326x)as using the same diff case.
This would explain why my old truck/carrier needed machining to fit.
I'm still a bit sketchy on how to positively identify my axle though. There is no cast number on the webbing of the housing, and I cant find any stamped numbers on the axle tube. The cover tag has rotted away to the point that it is not ledgable.
TRENDZ
Postby Mark Nixon » Wed Jan 13, 2010 2:31 pm
A 3.07 rear axle (D-71) has an extra machined spot at the top of the center section, just to the right of the diff cover.
AFAIK there are no stock D-71 3.07 geared rear ends with the 35 spline axles.
You could likely MAKE one, though.
I do believe there are at least 2 separate bearing sizes for either dually rear (C&C or pick-up) and the 1-ton single rear, 3.07 included.
Re:
Postby Douglas » Fri Apr 16, 2010 3:38 am
Mark Nixon wrote:AFAIK there are no stock D-71 3.07 geared rear ends with the 35 spline axles.
hey-Hey!!!,
There is indeed 35-spline, 3.07 Powr-Lok made; I just got one. needs much rehabilitation in terms of clutch packs and carrier bearings...:) Studs/cones on the hubs. I believe the studs/cones is the differentiator for 35-spline D70's in Dodge apps.
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: DANA 70 identifiers
Postby dunes450r » Sun Nov 28, 2010 9:14 pm
i've heard reference here that if you axles are held with cone locs and nuts you have a 35 spline axle, if thats true then i have a 3.07 35 spline D70 in my 90 W250......
dunes450r
Postby Mark Nixon » Sun Nov 28, 2010 9:37 pm
That is true.
Since I posted that last comment, I have found several that indeed are 35 spline and have the studs/nuts/cones, not the bolts.
Postby Richie O » Mon Nov 29, 2010 4:07 pm
In my reading circle I have yet to read anyone with a 32 spline 3.07. Even if you had the super rare intercooled truck with them.
Postby Mark Nixon » Mon Nov 29, 2010 4:47 pm
I have an '89 3.07 geared axle and a '91 3.07 one here, I'll pull and axle on each and try to clear this up, one way or another.
Postby crossy » Sat Apr 26, 2014 10:41 am
MARK, and what was the verdict 4 years ago. lol . how about an actual part number of aftermarket units that will fit a 3.07 Dana71 or 70 HD as it is called?? thanx , crossy
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Postby PToombs » Sat Apr 26, 2014 6:00 pm
Mark isn't here any more, you need to try some of the other forums, I think he's on 1 or 2 others.
Postby mknittle » Mon Apr 28, 2014 6:56 am
PToombs wrote:Mark isn't here any more, you need to try some of the other forums, I think he's on 1 or 2 others.
Try here He has posted recently I the thread "What did you do to your gen1 today?"
http://www.dieseltruckresource.com/dev/ ... s-f93.html
mknittle
