Jacking up front of 1993 w250
Postby terex » Wed Jan 27, 2010 3:14 pm
Owners manual says "When changing a front wheel, place jack under the outside of the spring mounting bracket". And shows a front view drawing, with 2 arrows pointing upward. Is it the front bracket or rear bracket? Rear looks stronger, but you are picking up more of the truck-front looks weaker, but you are lifting less.[/url]
terex
Postby ahale2772 » Wed Jan 27, 2010 4:51 pm
just lift off the axle... ur going to have to left 5 extra inches of truck before the wheel gets off the ground
