Will a 15" wheel fit?
Postby bnorth » Wed Feb 03, 2010 10:09 am
Hey guys I was wondering if anyone has run 15's on a W250. I'm looking for some bigger rubber and most of the guys selling mud terrains around here for good prices have 15" tires. Let me know your findings.
92W250 club cab, a518, d60/d70lsd, front leveled 2", indexed fuel pin, ground washer, 4" straight pipe, K&N, high idle screw MIA, 9" pro comp lights, OD on a potentiometer, 366 spring waiting to go in.
bnorth
Postby pulltilbroke » Wed Feb 03, 2010 2:03 pm
They will fit on the rear but they won't fit over the brakes on the front
Postby RSWORDS » Wed Feb 03, 2010 5:20 pm
I've seen alot of guys on pirate4x4 grind down the calipers to make em fit on the front, weather or not you feel OK with that is up to you... I've never done it but would if need be, youdon need to take off much.
RSWORDS
Postby bnorth » Wed Feb 03, 2010 7:07 pm
Ok I figured they could fit with some grinding I was hoping to find someone that had done it. That has some advice etc.
bnorth
