by Mark Nixon » Sat Feb 06, 2010 10:34 am
If you've ever had a trailer WITH BRAKES, try one with a good set.
You'll never want one without them.
Federal Law requires braking axle(s) and a breakaway system for trailers over 3,000 pounds and they require it on ALL WHEELS TOUCHING THE GROUND.
Most STATES require at least 1 braking axle on a muti-axle trailer, along with a breakaway system.
Trailer brakes, electric or hydro-surge, aren't the most responsive, nor the strongest, but the control you have with them, after having not had them, is definitely noticeable.
It also stands to reason, would you drive a car/truck that had no brakes at all?
Then why pull the same vehicle and weight with no brakes, behind a truck designed to carry only half again it's own weight in braking, too?
The biggest mistake I've seen is people not keeping them maintained.
If you go long distances all the time with your trailer, when you grease and change oil on the truck that pulls it, you should adjust the brakes and lube the trailer, too.
They are extremely sensitive to adjustment.
Pull hubs and re-pack wheel bearings AT LEAST once a year.
Remember, with the absolute control of Law Enforcement, you can get stopped for ANYTHING, and getting tickets for faulty equipment in the process isn't unheard of.
