Front spenchun parts.
Postby Rebel Ram » Thu May 17, 2007 7:08 pm
While shopping on Napa's online catalog for front end suspension parts such as Bushing and ball joints, the site has options for #4000 axle and w/o. And threaded type ball joints and non threaded. Without disassembly first how can I know which parts to order?
"Big Ugly"-93 3/4 T extra cab 4X4 5 speed
"Big Hips"-92 1 Ton reg cab 4X2 Auto
"The ohwun"-2001 3/4 T quad cab 4X4 auto
Rebel Ram
Postby Greenleaf » Fri May 18, 2007 9:17 am
Your asking the right guy. I JUST completed the complete rebuild of two trucks. 1990 D250 and my 1992 D250. Everything was replaced. No joke. I used almost all NAPA items outside the sway bar bushing/links.
It's best if you call me at the shop during the day. I get off work at 3:00 pm.
419 895 1700 ext 5012
Greenleaf
tech specialist/mod
Postby CAJUN 93 » Fri May 18, 2007 12:59 pm
i know all the 350's have 4000 lb axles. i dont know for sure on the 250's.
you can pm me the last nine digits of your vin # and i can send (either fax or snail mail) you a printed build sheet for you truck (that goes for you other guys too.) its an extended version of the tag on the bottom of the hood and its kinda handy to have.
daryl
CAJUN 93
Postby Rebel Ram » Fri May 18, 2007 5:08 pm
Excelent! I'll be out in the garage tomorow and I'll look at the No.s,
How was the fit with the Napa parts? Did you spring for the premium (more expensive) parts on Napa's list or no? Were you able to save the eccentric bolts and reuse them? Those are the parts that my alignment guy told me are spendy when you can find them. Hopefully mine are OK.
Rebel Ram
Postby Greenleaf » Thu May 24, 2007 3:00 am
I purchased the best NAPA line. It cost a small fortune to do both trucks. I was suprised to find tha ball joints were not too bad. Some felt really good still. The tie rods (I think there are like nine of them :evil: ) also felt good. I still replaced them all though.................
I saved the cam bolts. It took some work though on the 92 as it has seen loads of salt. I had to cut the portion of the cross member away that holds them.
The 250 don't all have the 4000 lb axle. My 92 does. The 90 is a 3860 lb rate. However the parts are all the same. I even used some "yard" parts from a 1993 D350 like the upper/lower control arms.
Greenleaf
tech specialist/mod
Postby dpuckett » Sat May 26, 2007 7:58 pm
I WAS using MOOG ball joints, but had one go bad, so I am now trying the Spicer brand ball joints (GF says they have held up in 3rdGen 4x4s). They actually look and feel heavier than the MOOG. I dont like to buy stuff from NAPA, cause I cant get a brand name for 90% of the stuff. I'd like to know who made it and where it came from.
For ANY vehicle with the Cummins B series in it, I'd recommend the premium line of anything front end related, esp in the 2wds- they are horribly under engineered in the Dodges.
Daniel
Postby 93 dually » Thu Jun 14, 2007 1:45 am
www. espo.com they have a compleat kit for our trucks 250.00 with poly bushings thats what i just ordered for my truck 192000 miles the old girl is ready for some new frontend parts :lol:
1993 d 350 htt turbo 5in stacks high flow intake .butchered fuel pin
93 dually
Postby 93 dually » Thu Jun 14, 2007 1:48 am
by they way you can get your weight inside your drivers door mine is 3880 for a d350 hope i could help
93 dually
