my 93 d350 project
my 93 d350 project
Postby diesel freak01 » Wed Sep 15, 2010 7:33 am
ok so i finally have started my frame swap project this week. Mark Nixon you were very correct in saying this frame was clean, and thank you. i have almost completely sandblasted the frame and it looks great, should be painted by the weekend. now for my source problems. i have found a supplier for the cab corners and extensions for my ext cab. but the few other things i need are a complete brake line kit, wanted ss but dont wanna give $350 for it so i guess normal steel lines will do. im going to do a 1/2 draw straw and lines. need good rear brakes and adjusters. also need the front cover gasket but i think my local truck shop can get it.
biggest problem i am having is finding my rear overload springs, the ones i have go under the spring pack. local shop wants 4-600 to make them :shock: . anybody have any or have an better ideas?
does anyone know if the diamond eye exhaust kit will fit an hx-40? or just need a different downpipe?
thanks for all the help guys! :grin:
*edit changed the topic and added pics
Last edited by diesel freak01 on Thu Sep 16, 2010 5:34 pm, edited 1 time in total.
1993 d350 ctd drw 2wd auto
diesel freak01
Re: anybody know some good sources?
Postby RumbleFish » Wed Sep 15, 2010 11:38 am
i have a set of factory overload springs, spacers, and brackets. mix in some ubolts and you are set. these are off a 1990 D350, the ones that go over the main spring pack. im 8 miles from the ohio line.
Postby BobS » Wed Sep 15, 2010 2:21 pm
I roll my own brake lines. I used the rust resistant S.U.R.&R. - Innovative Automotive Solutions 3/16" E-Z Bend brake Tubing # BR-EZ100 which is sold by www.fuelsender.com I bought mine at my local Carquest auto parts store. It looks like copper & bends like copper but when you touch it to a grinder it makes sparks. It think one of the trade names is Cunifer.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Richie O » Wed Sep 15, 2010 5:46 pm
BobS wrote: It looks like copper & bends like copper but when you touch it to a grinder it makes sparks. It think one of the trade names is Cunifer.
I think I came across this on my Wrangler project. When I was pulling the front end I saw ( what I thought was) copper line.
Postby PToombs » Wed Sep 15, 2010 5:50 pm
Richie O wrote: When I was pulling the front end I saw ( what I thought was) copper line.
Where you are, it probably was.......... ;)
Postby diesel freak01 » Thu Sep 16, 2010 4:47 am
thanks for the input guys, i have found a brake kit from jcwhitney for 15 bucks so i may go that route or a universal kit from somewhere.
anybody have any other ideas that i should do while i have it apart? i plan on the kdp at least.
diesel freak01
Postby ellis93 » Thu Sep 16, 2010 6:07 am
Man alive. Are u really wanting to cheap out on ur brakes. I don't mean to step on toes here but,for me, I would never play with mine. If I were to redo my braking system I would use parts that were of good quality.
Postby diesel freak01 » Thu Sep 16, 2010 6:30 am
well from i read it is a 25' roll of brake line so i dont think its really cheaping out, but like i said im going to look around some more i dont really want to buy sticks and piece it together i would rather run continuous lines and i have all the tools to do it right so why not just buy a roll and go with it?
diesel freak01
Postby ellis93 » Thu Sep 16, 2010 6:54 am
What I was getting at is all brake tubing is not the same. That cheap stuff is more than likly gonna be hard to make a clean flare on. It may try to split in the flare and also would never make a double flare. As far as using stick tubing, many oem apps use unions(not compression unions)on the rear line. Ford and chevy in the last ten years have. Stick tubing can be had in 7 or 8 foot sections so really u could work it to only one union.
Postby BobS » Thu Sep 16, 2010 8:11 am
FWIW; it took over 40+ years for the brake line manufacturers & me to meet up with the tubing that I described above. This stuff cuts, bends, and flares like no other brake line I have ever used. The antirust qualities alone to me over justify the increased price. I remember buying NAPA precut tubing in the 60' & 70's that was never the right length and having to make "line coils" just to take up the slack. I seen this same old NAPA tubing rust out in 3 years or less!! It's your choice but for me I really do not like having to redo brake lines because they corroded.
BobS
89 D350 Stock
BobS
Postby TRENDZ » Thu Sep 16, 2010 4:43 pm
Summit racing has 25' rolls of stainless tubing that bends and flares beautifully. They also have stainless fitting kits that include every fitting needed for our trucks. I used it and would never use anything else again.
TRENDZ
Postby diesel freak01 » Thu Sep 16, 2010 5:33 pm
diesel freak01
Re: my 93 d350 project
Postby diesel freak01 » Sun Aug 25, 2013 3:48 pm
Well thread resurrection time!
Got the ol girl in the garage yesterday and been tinkering. Got the lp piston pump on. Engine still spins but the starter is frozen. Got the wiring harness changed over.
Now for the questions. Does anyone repop fenders? What size are stock fuel lines? What's a good rust stopper?
diesel freak01
Postby dazedandconfused » Sun Aug 25, 2013 4:29 pm
Yeah they Repop doors, fenders and some other panels but they suck and don't fit worth a crap.
Postby diesel freak01 » Mon Aug 26, 2013 6:48 am
Ok well that figures. Anybody have any leads on good clean fenders? It is an LE truck and i had noticed that the ones that i found only fit the base model, ie without the trim holes. If not i guess i will put the crusty ones on until i find something. I bought a parts truck last year that has good inner fenders but the outers are in about the same shape as mine.
diesel freak01
