35 in tires
35 in tires
Postby good ol boy » Wed Jan 05, 2011 11:47 pm
will 35 inch tires fit on a stock 1990 4x4 not worried about a lil rubbing ill just be careful if thats the case, been through that wit my buddies 06 haha
1990 5 spd, hx 35, fuel cranked, other minor pump ajustments, pod injectors, coolertubes intake horn, denny t stage 2, finishing restoration, new cab, a fender, a door, front bumper, mirrors, fresh paint, etc...Things in progress, 1\8 in timing bump, 6 in mitre cut stacks, wheels and 35 in tires
good ol boy
Re: 35 in tires
Postby Richie O » Thu Jan 06, 2011 10:36 am
I'm gonna say no. My 89 with 33,12.5's rub some.
Re: 35 in tires
Postby burnt_servo » Thu Jan 06, 2011 7:03 pm
i ran 34 inch super swampers ( 9.50 x 34 ) on my 77 powerwagon and i had to trim the bottom of the fenders closest to the door about a 1/2 " .
i have a set of 35's for my '93 and i expect to have to put a pretty good arch into the spings to make them clear the fenders .
'93 w250 .... stock ...
burnt_servo
Re: 35 in tires
Postby good ol boy » Fri Jan 07, 2011 10:25 am
i might just have to try it my 33 12.50 didnt rub and if they do rub would the best thing probly just get a 4 in lift? i dnt want it to sit up off the tires to high i like the tire to fill the fender wells for the most part
good ol boy
Re: 35 in tires
Postby dunes450r » Fri Jan 07, 2011 8:16 pm
i have 33x12.5's as well and they rub on the right side occasionally (i think the fender has been hit or something before i owned it)
i would say your best bet to fit 35's would be fender cutouts/flares. some of them look good and i agree that a no lift rig clearing 35's looks better JMO
dunes450r
Re: 35 in tires
Postby lectro_static » Mon Jan 10, 2011 12:09 pm
my 33/12.50s hit so I put lift shackles on the front, ended up leveling the truck and the tires dont hit anymore
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Re: 35 in tires
Postby StefonC » Mon Jan 10, 2011 6:23 pm
I'm sure with a 2 inch leveling kit you can run 35's without rubbing right?
StefonC
Re: 35 in tires
Postby wonderbread » Mon Jan 24, 2011 7:48 pm
Any idea where to start out looking for a leveling kit?
86 Ramcharger 318 soon to be 1st Gen 12v, with 250 running gear
wonderbread
Re: 35 in tires
Postby ahale2772 » Tue Jan 25, 2011 4:46 am
home made!! only thing to remember is (at least on my truck) the drive shaft angle gets real steep real fast...
(my 33 12.5's used to rub then i lifted the front 3 inches and they dont...so yes 3-4 inches will work)
Re: 35 in tires
Postby lopez dodge » Thu Jan 27, 2011 12:40 pm
mine fit with about 4" re arched springs and 315/70/17's
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
