Power steering pulling back and forth
Postby IrishChamp » Wed Jan 19, 2011 6:45 pm
This started a few months ago but went away and now it's back.
The power steering seems to not respond properly, after coming out of a turn it tends to want to go further in what ever directing your turning before it starts going the new direction. It doesn't fight what I'm doing it just goes a fraction too far in each direction. Coming out of a corner it's hard to get it going perfectly straight; it keeps going a fraction too far so I correct the other way then it goes back and forth, back and forth, as I correct then it corrects again. It doesn't cause any serious danger but it's very strange.
1993 W250, 115k miles, pump turned up, M&H Timing Spacer, built a518 w/ steel stator spec rite, he351ve, 16" steel wheels, 255/85r16 BFG Km2's
IrishChamp
Re: Power steering pulling back and forth
Postby chrislib » Wed Jan 19, 2011 7:28 pm
Possibly an outer u-joint at the knuckle seizing.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby IrishChamp » Wed Jan 19, 2011 11:16 pm
I had the rear u joints replaced last year, should have had them look at the front too.
chrislib wrote:Possibly an outer u-joint at the knuckle seizing.
IrishChamp
Postby Richie O » Thu Jan 20, 2011 3:02 pm
I agree. A bad axle joint will cause feedback in the wheel. If that is the problem fix it soon or you will be looking for an inner and outer axle shaft. I worked on a buddies truck today ( one of my old cummins ) putting in a starter and noticed his was bad too. I thought when I sold the truck a couple years back I was done working on it, guess not. 8)
Postby BobS » Thu Jan 20, 2011 3:39 pm
Fractured frame where the steering box bolts on or a broken mounting bracket between the box and frame. This gives the leading and lagging steering effect.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby IrishChamp » Fri Jan 21, 2011 3:30 pm
A buddy helped me and we jiggled the steering wheel with the truck off and looked over everything. Nothing looked broken or lose. The passenger side shaft had a little in/out play but when we jacked up the front and tried to wiggle it there was no in/out or side to side play in the wheel so I think that's ok.
I'm over due for greasing everything so I'm going to start there.
Can someone recommend a good grease and grease gun? Also what are all the necessary grease points on the truck?
I want to give it a good once over.
I found 3 nipples on each side in the front.
I'd like to address any squeak points as well.
Do the leaf springs need lube?
How about bushings and mounts?
I'm sure my differentials need some attention too.
Again, I'm ignorant about lubeing my trucks joints, bearings etc so if someone could point me towards some info Or point out what areas need lubeing and what lube I need for different areas that would be great.
EDIT: harbor freight has a pneumatic/air compressor grease gun for $20, Any experience with this?
IrishChamp
Postby PToombs » Fri Jan 21, 2011 6:53 pm
No grease or lube on the springs or bushings. Just the basics on the steering, and ball joints if they've been replaced, u-joints, driveshafts, etc.
On the HF grease gun, they suck. Guy at work bought one and wasn't happy with it. His biggest complaint was that you have to hit the button for each shot of grease. It won't keep pumping if you hold the trigger. I think it kept getting air bound too, among other problems.
Postby ellis93 » Fri Jan 21, 2011 7:44 pm
Buy a pistol grip grease gun and you'll not be sorry. If that is not your flavor, spend the money on an electric one from Lincoln. I wouldn't if its not an every day job though. Those are higher that giraffe nuts.
Postby Richie O » Fri Jan 21, 2011 8:56 pm
I have a couple lincoln cordless ones. NICE is all I can say. Batteries don't last forever and its cheaper to buy a total new gun, battery, charger set then it is to get just 2 batteries. ( hence the reason why I have 2 :evil: ) I also have a air gun, but don't use to often.
Postby IrishChamp » Sat Jan 22, 2011 12:01 am
Thank you guys. I will not grease or lube the bushings or springs.
Is there a more affordable alternative to a Lincoln grease gun? It seems to be the most popular but too spendy! I've heard the manual ones don't have enough force to push grease sometimes.
How about a recommendation on a quality grease?
IrishChamp
Postby ellis93 » Sat Jan 22, 2011 4:34 am
I use this
http://shop.advanceautoparts.com/1/1/60 ... 10005.html
If a quality grease gun is bought then pressure should not be a problem. I use a pistol grip on small jobs and don't have any problems. If you can not push grease thru a fitting with one then the fitting is stoped up or the part that your greasing is dried up.
Postby Richie O » Sat Jan 22, 2011 9:55 am
You actually get more pressure from a manual grease gun. I get some on the equipment sometimes that the auto gun will just bypass. Have to get out the pump one and go for it.
Postby ellis93 » Sat Jan 22, 2011 3:03 pm
Mr RichieO I took the regulator out of mine. Made a word of difference.
Postby IrishChamp » Sat Jan 22, 2011 4:33 pm
I picked up a Lucas manual grease gun and some Lucas red and tacky grease today, Hopefully it fixes the problem, although currently there are no symptoms. Grrrrrr
IrishChamp
Postby PToombs » Sat Jan 22, 2011 6:12 pm
Did you ever check the axle u-joints? Turn the front wheels a little and then spin them. If a u-joint is bad the wheel will spin hard.
