radiator fitment
radiator fitment
Postby manyholes » Sun Feb 27, 2011 3:12 pm
hey guys, im away from my trucks for a lil bit but was wondering if a rad from a 91 w250 gaspot will be a bolt in affair for the 90 w250 diesel?? im only asking cause i am stripping the gas job down for parts since it got sideswiped and i put a new aluminum rad 2 core rad in it last summer and the diesels is fine for now but showing age
thanks
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: radiator fitment
Postby thumpertrev » Mon Feb 28, 2011 6:28 pm
My parts source shows different part numbers...so I doubt it.
1994 Ford crew cab dually.Turbos-WH1C over a TV8102,3" charge piping,largest aluminum I/C I could fit,5" turbo back,SDX11 5x12,mild head porting,ARP studs,Throttle mod,ground pin,366 spring, fuel screw bottomed(no runaway),A518 with low stall converter.
thumpertrev
Postby manyholes » Mon Feb 28, 2011 8:53 pm
thanks for checking thumpertrev
is there are recomended upgraded rad for these trucks??
manyholes
Postby thumpertrev » Mon Mar 07, 2011 6:36 pm
I dont remember which but, I read that Be Cool or maybe Griffin makes an all aluminum unit.
thumpertrev
