need help pm'ing people
Moderator: BC847
Postby nyford » Fri May 31, 2013 6:06 am
Is this function turned off for those new members without 25 posts?
I was a member before the 25 post count thing happened, did a lot of lurking.
nyford
Re: need help pm'ing people
Postby CumminsPower59 » Fri May 31, 2013 7:08 am
I believe so. BC will chime in eventually, I'm sure he can help you out. Your only four posts away from 25 anyways ;)
Postby BC847 » Fri May 31, 2013 8:55 am
Try it again.
For some reason, you were a memeber of the Newly Registered Memebers and Registered Members. The former will not allow access to the PM feature. I've removed you from that group leaving you in the registered members group. That should straighten thingas out.
If not, let me know here. :)
Postby nyford » Fri May 31, 2013 9:05 am
Works now. Thanks
Fummins project. 89 f350 w 95 front end, 4x4 dually crew cab, 89 6bt, pump tweeked, studded, marine 370's, intercooled, 4" turbo back, 12 cm housing, nv 4500. divorced 205, 4.11's, 265/70/19.5's
nyford
Return to 1st Gen.org News
