3 HOLE GAUGE POD.
Moderator: BC847
Re: 3 HOLE GAUGE POD.
Postby DMan1198 » Mon Jan 20, 2014 11:53 am
Not really. The injectors and rails have been tested to over 30,000 psi which is very difficult to hit (especially with a sensor that only goes to 26,000) the rail also has a relief valve that unless shimmed or plugged won't exceed a certain pressure. My truck has a 30,000 psi rail pressure sensor, but rarely can you tune the truck to exceed 26,000 (the computer just won't let you) you can crank up the duration a lot, but often rail pressure doesn't get cranked up
Postby ihredneck » Mon Jan 20, 2014 12:21 pm
DMan1198 wrote:Not really. The injectors and rails have been tested to over 30,000 psi which is very difficult to hit (especially with a sensor that only goes to 26,000) the rail also has a relief valve that unless shimmed or plugged won't exceed a certain pressure. My truck has a 30,000 psi rail pressure sensor, but rarely can you tune the truck to exceed 26,000 (the computer just won't let you) you can crank up the duration a lot, but often rail pressure doesn't get cranked up
Do you know the duration that the test goes for? I could see the body or nozzle holding up to that psi, but their is a nasty term called plastic deformation... :|
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
Postby DMan1198 » Mon Jan 20, 2014 5:20 pm
Well if it's Bosch stuff then the testing is probably extensive and until it's broken. I do think its a good idea to have a rail pressure gauge (my mini maxx has the ability to read it, but I also have the mcc software on my laptop so I can modify 4th gen tunes to my hearts content. Factory setting is a hair over 26,000 psi and that is ONLY under high load/high rpm. Other than that it doesn't break 20k) just saying it's highly unlikely you're going to blow an injector or rail with a tuner. Especially since tuners rarely play with rail pressure. H&s leaves a very good amount of maps alone on their box tunes (from the looks of it rp, pilot, I think they even leave post alone, they leave all but 4 turbo maps alone, and while add timing they use the factory table which looks awful. Worst maps I've seen are by far rail pressure. They're very spiky)
Return to 1st Gen.org News
