please report problems (unable to log on,server issues,etc.)
Moderator: BC847
Postby swank » Fri Jan 05, 2007 6:45 am
just like the title says. it'll give me some info to go after the host if needed.
swank
Postby DLittle » Fri Jan 05, 2007 8:27 am
Don't know if it's my computer but I have to log in everytime I visit and then I have to enter my username and pass twice before it says I'm logged in. Yes I hit the remember me box everytime. This is the only site that I visit thats doesn't remember me. Is it just me?
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby MUDDY » Fri Jan 05, 2007 8:48 am
DLittle wrote:Don't know if it's my computer but I have to log in everytime I visit and then I have to enter my username and pass twice before it says I'm logged in. Yes I hit the remember me box everytime. This is the only site that I visit thats doesn't remember me. Is it just me?
no prob here
97 D-3500 flatbed dually 385/837
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
http://www.idahoturbodiesels.com
MUDDY
Postby Paccool » Fri Jan 05, 2007 12:59 pm
Mine is doing the same thing as Dlittle is reporting. A couple of times it has been ok but I usually have to enter my name and password twice even when I have the "log me in automatically" box checked. I don't dump my cookies but once every few weeks so it isn't that.
Swank, I also sent this as a PM cause it said it didn't post????
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby Greenleaf » Fri Jan 05, 2007 1:17 pm
I see the same thing. I have to log in as well.
I also get a screen that tells me a post attempt didn't work. However, if I click back to the prev. page, it works.
I work with it. On another forum, I have to click on the "run scripts" box six times for each page I look at. :roll: :!: :x
Greenleaf
tech specialist/mod
Postby TugboatPhil » Sun Jan 07, 2007 8:44 am
I've also gotten the "Problem Posting" message a couple of times. But I reloaded the page and it was there.
**EDIT - I got it again and here is what it looks like
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, support@supportwebsite.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
Apache/1.3.33 Server at 1stgen.org Port 80
- EDIT**
Otherwise, great forum! Thanks, Swank. :wink:
93 D350, Modifed by Smokehouse Diesel, Ashland, Ohio.
Truck renamed by wife as "The Global Warmer."
TugboatPhil
Postby wannadiesel » Mon Jan 08, 2007 5:24 pm
I just got one of the same.
Best dyno: 408/844
wannadiesel
diesel guru
I am having a hard time posting here
Postby BRUISER » Wed Jan 10, 2007 5:46 am
It seems that it will not let me log on.
I log on and it accepts my user name and password but does not say I m logged in.
I have hecked my cookies etc.. and the are all turned on..
YOu may want to check into this..
also after I try for 5 times an finally get in, I then go to a different site and come back in lets say 5 mins I am now logged out and YES I did check the box that keps you logged in
Ken C
'92 W250 4x4 - 5 Speed
www.impaks.com ( my projects )
www.nc4x4.com ( Moderator )
www.cnc4x4.org ( VP )
BRUISER
Re: I am having a hard time posting here
Postby BRUISER » Wed Jan 10, 2007 5:47 am
BRUISER wrote:It seems that it will not let me log on.
NOw to add to this when I hit SUBMIT I got tihs error:
Ken C
BRUISER
Postby BobS » Thu Jan 11, 2007 5:37 am
TugboatPhil wrote:I've also gotten the "Problem Posting" message a couple of times. But I reloaded the page and it was there.
- EDIT**
I just started getting this same error message today. Otherwise the post goes thru.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Picture?
Postby Bluebird » Thu Jan 11, 2007 8:51 pm
How do I place a picture in my post box?
Thanks, Patrick.
1993 Patriot Blue reg-cab CTD D250 LE; auto; 3.54LSD;BHAF; 3" straight-pipe/14:Magnaflow; MagHytec diff-cover;ARE lid matches hood; 222,000 and rolling; 133HP/311TQ; 17-23mpg.
Bluebird
Postby MUDDY » Thu Jan 11, 2007 9:33 pm
ya need to use photobucket. works well.
93 D-350 dually
90 W-250
MUDDY
Postby MUDDY » Thu Jan 11, 2007 10:07 pm
MUDDY
Postby BEARKILLER » Mon Jan 22, 2007 5:22 pm
Same story as everyone else.
Can't log in sometimes.
Other times, it takes several attempts.
Also get the "can't connect server" page.
One good thing I will say, things work in a flash, no hesitation or waiting.
BEARKILLER
Return to 1st Gen.org News
