SOMETHING IS GOING HAYWIRE
Moderator: BC847
Postby BEARKILLER » Sun May 13, 2007 9:37 pm
Ever since the beginning, I have had to log in twice each visit.
Sometimes it will remember me for days, providing I don't visit the site during that time; then, it won't remember me twice in the same day.
Now, it logs me out when I click from post to post.
I can be reading something, then click on something else, and I am no longer logged in.
I had to jump through hoops to get this posted and not sure it will work at that.
Is it just me, or everyone else??
Thanks.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby wannadiesel » Mon May 14, 2007 5:14 pm
Are your cookies turned on?
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Mon May 14, 2007 5:16 pm
When I log in, I go to Messages, log in, then to the forum. When I went to log straight in, it would make me do it twice, then tell me there were no posts since my last visit! :roll:
Postby BEARKILLER » Tue May 15, 2007 10:24 pm
wannadiesel wrote:Are your cookies turned on?
Goodness, I don't know.
How would I know??
If they ain't turned on, how do I go about turning them on??
This is all WAY over my head.
BEARKILLER
Postby BEARKILLER » Tue Jun 26, 2007 7:36 pm
This is getting ridiculous :evil: .
Now, I can log in (it takes twice to take); then, when I try to reply to something, it tells me I am not logged in, and I have to do it all over again.
Other times, I can just be navigating through posts/threads, and it will just log me out.
I have no idea what cookies are, where they are at, nor what to do to fix, or turn them on.
I need some help, please.
Thanks.
BEARKILLER
Postby wannadiesel » Wed Jun 27, 2007 4:37 pm
Are you using Internet Explorer?
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Wed Jun 27, 2007 5:02 pm
I tried logging in directly last week, the normal way. It did the same crap it usually does, tells me to log in then no new posts!
Still works good if I go thru messages.
Postby BEARKILLER » Fri Jun 29, 2007 3:08 am
wannadiesel wrote:Are you using Internet Explorer?
I think so; at least, that is what it says at the bottom of the screen.
BEARKILLER
Postby wannadiesel » Fri Jun 29, 2007 3:06 pm
Go to "tools", then "privacy" and make sure it's set no higher than "medium." Try knocking it back a notch if it's already there.
Best dyno: 408/844
wannadiesel
diesel guru
Return to 1st Gen.org News
