Overdrive Fail Safe
Overdrive Fail Safe
Postby Greenleaf » Thu Jan 04, 2007 9:50 am
I have found that the speed sensor will go AWOL and, although one can drive w/out the speedo and cruise, it's tough w/out the OD
A switch installed somewhere inside the cab can by-pass the VSS and provide the ground circuit for the OS solenoid. I tapped into the wire at the large harness directly on top of the brake booster. It's an easy spot. I used a headlamp hi-low beam switch and mounted it to the floor. Used two of the three terminals. Grounding one to the floor (or under dash).
I can now control OD shift by this floor mount switch or the manual switch on the dash and shifter lever. You guys w/autos are installing the new shifter lever/switch assy .......right!?
Greenleaf
tech specialist/mod
Postby eyoung429 » Thu Jan 04, 2007 2:47 pm
I actually did mine just by adding a toggle switch to the shift lever for the time being..dash switch didn't work when I got her.
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby TOMTOM » Sat Jan 06, 2007 8:39 pm
Is wrecking yard still the best place to get shift lever? Any one know how mutch they are from dealer? I have to use o/d in 1/4 mi. cause my gearing is too low (3:54). hate to lean forward to turn on o/d.
93 CLUB CAB LE SHORT BED 209,000 MILES AUTO/OD 3.54 GEARS 4" TURBO BACK EX NO MUFFLER P7100 PUMP MODS B/D INJECTORS 13.55@99 MPH 440HP 967TQ ON #2 ONLY. PSD INTERCOOLER,BD SUPER B TURBO)47RE FULL MAN SUNCOAST TRIPLE DISC
TOMTOM
Postby TugboatPhil » Sun Jan 07, 2007 8:40 am
I don't know about getting them at salvage. They might not want to part out a steering column. I got mine at the dealer a few years ago and I think it was about $37. I have also seen them on EBay.
93 D350, Modifed by Smokehouse Diesel, Ashland, Ohio.
Truck renamed by wife as "The Global Warmer."
TugboatPhil
Postby CAJUN 93 » Wed Jan 10, 2007 8:37 am
let me know the application your useing and i'll post a part # and current prices
CAJUN 93
2nd gen auto shift lever
Postby Firstgenfanatic » Wed Oct 01, 2008 4:58 pm
I just scored a 2nd gen auto shift lever for $20. on Craigslist. I was just in the right place at the right time. :D The dealership sells them new for around $35.
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Re: Overdrive Fail Safe
Postby hp383 » Fri Jun 11, 2010 6:30 pm
What is this shift lever you speak of?
hp383
Postby Gots_a_sol » Fri Jun 11, 2010 7:29 pm
-Joe
Gots_a_sol
