Ramcharger buckets.
Ramcharger buckets.
Postby 1stgenblowingsmoke » Sat Aug 27, 2011 4:28 pm
This isn't very indepth but here's my ramcharger seat install.
I hope you can see the factory bench seat mounting holes the two outer holes for the buckets use those same two holes. For the other two holes I just drilled them into the floor n put some big washers on the bottom then bolted the seat brackets down.
I had to trim about two inches forward however wide the brackets went then about two inches off the back of the carpet for them to fit right.
I have a pic somewhere with the pass side seat bracket mounted in but can't find it anyway here is the end result.
90 LE 250 reg cab 4x4 5 speed getrag. Fuel screw turned to factory stop, throttle rod mod, 3.5in flow through exhaust, #75 fuel pin rotated, HX-35 waiting to on along with an intercooler.
1stgenblowingsmoke
Re: Ramcharger buckets.
Seams my pics got cut off on the right.
1stgenblowingsmoke
Postby Richie O » Sat Aug 27, 2011 6:28 pm
Not on my screen.
Postby 1stgenblowingsmoke » Sat Aug 27, 2011 8:45 pm
Well that's weird it should show the seat backs but wont for me.
1stgenblowingsmoke
Postby oldestof11 » Sat Aug 27, 2011 9:59 pm
Go to User Control Panel and pick a different forum style.
Otherwise looks great!
Postby 1STGENFARMBOY » Thu Sep 01, 2011 2:37 pm
I have the same buckets and same covers.
Postby 1stgenblowingsmoke » Fri Sep 02, 2011 8:35 pm
1STGENFARMBOY wrote:I have the same buckets and same covers.
What do you think of em I love mine makes the ride feel a little less jarring.
1stgenblowingsmoke
Postby bmoeller » Mon Feb 27, 2012 6:18 pm
I sure like mine! :D FAR more comfortable than the bench they replaced. Great to be able to adjust the angle of the seat back too.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby 1stgenblowingsmoke » Mon Feb 27, 2012 7:05 pm
I loved em too except mine didn't recline till I put a 2nd gen power seat bracket on the drivers side. Sadly they went to the wrecked with the truck. :( :( :(
1stgenblowingsmoke
