questions on 4x4 conversion.
Postby bsmithcummmins » Mon Aug 27, 2012 8:49 pm
Hi so im wanting to do a 4x4 swap on my 2wd cummins, its is an 89 non intercooled automatic. I kind of figure it cant be too horribly hard, bassically just take all the 2wd stuff off, build some shackles, mounts for shocks, custom driveline and throw on tcase. I know it wont be all that easy but im wondering if there are lots of small things that add up to make it a fairly hard project. What kind of prices should i pay for the axle, and tcase. how much should it cost in the end if i do most or all of the fab work? please give me some insight on some things i will need and the difficulty level of this. Thanks.
bsmithcummmins
Re: questions on 4x4 conversion.
Postby CumminsPower59 » Tue Aug 28, 2012 5:16 am
There have been several conversions here, might have to do some digging, but most, if not all your answers can be found. "1990" did a detailed conversion on his.
Postby cmann250 » Tue Aug 28, 2012 9:07 am
I was in your same posisition with the exact same truck. I've heard guys say they wouldn't to a 4x4 swap unless they had a pristine crew cab frame. To do it the the way the factory did would be quite a process, but there are short cuts that work just as well. That being said, I just live with a 2wd. The next one will have 2 live axles ;)
Postby coolhand_luke » Sun Jan 06, 2013 9:56 am
I'm looking at doing one also. I'm friends with a good welder/4x4 builder and he will do most of the hard stuff. I'm having trouble finding a t case and dodge Dana 60 though. I have found a bunch of Chevy d60s but not sure how they match up.
coolhand_luke
