Push button start for less than the cost of a starter relay
Postby hydroshok » Wed Sep 19, 2012 7:47 pm
My starter quit working. It was making a clicking noise like the solenoid needed rebuilt so I did that. The truck still would not start and I found the problem was the relay. The contacts on the starter solenoid were pretty much toast so it needed it anyway. I priced the relay and found a push button start switch from advance for a few dollars less. You splice the red wire and brown wire in the starter relay to the switch. I mounted mine in my ashtray. All you have to do is drill a 5/8" hole and tighten it up.
89 D350 5spd 83 crew cab: waiting on new drivetrain
1999 2500 5spd: 2001 HO motor, smarty, edge comp, 40hp injectors, AFE intake, AirDog, rebuilt NV4500, HX40, full air ride
hydroshok
