removing the TPS permently
Postby cummins king » Thu Nov 01, 2007 3:49 pm
i go a slush-omatic (automatic) and i got tired of alwas having to remove the tps and bracket, plus i think my was one the way out (can be very expencive to buy)
so go to this website and this guy explanes it alot better then i can
http://www.dieseltruckresource.com/dev/ ... p?t=142641
93 4X4 auto
cummins king
Postby dpuckett » Fri Nov 02, 2007 5:16 pm
Great idea. I think I'll do it to Mom's pickup when we swap for me to get a front end alignment. (Cant get a good one here in Cape G; sending it back to the swamp to get aligned).
DP
Postby PToombs » Sat Nov 03, 2007 5:02 pm
I've seen threads posted on how to put in a potentiometer, you can dial it to where you want it to shift. Seems to make life easier, and be the hot ticket! ;)
DP, I get a kick out of "back to the swamp"! :cyclopsani:
Postby cummins king » Sat Nov 03, 2007 6:41 pm
yes it works awsome
93 4X4 auto
cummins king
Dodge diesel
Postby Dodge Diesel » Mon Feb 11, 2008 5:48 pm
I have a 1993 dodge diesel turbo automatic 4x4. Does it improve your gas milage. I just bought a new TPS which cost 416 dollars I wish I knew this before but I might change it anyway it will be alot better. I need a fuel element if you know where there is any. It goes above your fuel filter it about the same diamter and is about inch thick with a plug on the end Thanks for the good information
Dodge Diesel
Postby cummins king » Mon Feb 11, 2008 5:51 pm
:shock: :shock: :shock: :shock: :o
wow, thats alot of money, i still have a good one, for cheap if you want to return that one :shock: :o
i realy like it, because you can change when the tranny goes in to OD, so when your cruzin at 80km or 55mile i think it is, you only spin 1400 or 1500 rpms
so ya it does help on fuel econ
93 4X4 auto
cummins king
Postby cummins king » Mon Feb 11, 2008 5:52 pm
oh yaand this cost me all of 3 bucks
93 4X4 auto
cummins king
Postby Rug_Trucker » Mon Jun 30, 2008 10:45 pm
This is cool! I printed that out.
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Postby 92 D/UNIT » Tue Jul 08, 2008 9:18 pm
does anybody have the part # for the dash pot?? i get and error message when i click the link.
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby cummins king » Wed Jul 09, 2008 11:43 am
doesnt look like they have the anymore
just grab the stuff from radio shack
93 4X4 auto
cummins king
Postby Firstgenfanatic » Mon Sep 07, 2009 7:49 pm
I just picked up my potentiometer items today at Radio Shack:
Potentiometer: 271-1720
Control Knob: 274-403
D-Sub Connectors: 276-1427
I really look forward to installing them. :D
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby Rug_Trucker » Tue Sep 08, 2009 4:35 am
These will work on a gas rig too? My nephew's '96-98 Ram maybe having problems.
74 Dart 225 4 DR
93 D350 CTD auto
Rug_Trucker
Postby PToombs » Tue Sep 08, 2009 5:40 pm
I bet not. On a diesel it tells the trans when to shift.
On a gasser, it tells the 'puter how much the plate is open and to fuel accordingly.
This is the short simple version. ;)
Re:
Postby BEARKILLER » Thu Jun 21, 2012 10:37 pm
Firstgenfanatic wrote:I just picked up my potentiometer items today at Radio Shack:
The # 271-1720 is an audio potentiometer and not really the best choice for this application.
The # 271-1714 is a LINEAR potentiometer and the better choice. ;)
#4 = 1991 D-350 LE Getrag
BEARKILLER
Re: removing the TPS permently
Postby bubba » Wed Jan 23, 2013 8:54 pm
Has anyone used these connectors? 276-1427? Because when I pull it up it shows a 9 pin connector, that I have never seen on my dodge lol
1992 Dodge W350 CTD A518 DRW Flatbed
bubba
