sdstriper wrote:If you buy a piece of pipe or tube with a longer tangent length than they normally come in, you can get your tube without welding 101. I bought 45* angle mandrel bent aluminum with 18" tangent lengths, then cut down both ends to get the fit I desired. It fits into my BHAF (no rubber fitting there) and has a rubber 45 with reducer (early H1C) at the turbo. Three T-bolt clamps. Around $75 If I remember correctly.
RumbleFish wrote:Where in the heck did you find a rubber 45? I've got a 3" (early H1C as well) aluminum 45, but I cannot for the life of me find a rubber 45 to go on the turbo. Enquiring minds want to know.....
Greenleaf wrote:Guys,
Do what you like, but the intake for a Bluebird bus TC 2000 w/Cummins 5.9 is what you need. End of story.
