I have a 12 volt compressor I bought for my air ride on my rat rod but was to slow. It builds 100 psi with no problem. It will fill the co2 tank I have for storage just fine.
BILTIT wrote:Start putting them into production!
PToombs wrote:How are you going to seal where the shaft comes out of the pipe? That was my other problem, I didn't want soot all over under the hood, and couldn't come up with a good sealing system that wasn't big or ugly.
rockbuggy4x4 wrote:Looks good so far. Hope it works when its done.
PToombs wrote:Those bushings are a good idea! I think I would have left that end open though, just in case you have a problem and need to lube or get at the shaft. It looks way better than what I cobbled up before I quit.
