Custom made FSS Steel plungers
Postby TRACTJDS0428 » Sun Aug 17, 2014 11:15 am
Im building Steel FSS plungers for anyone intersted. Common problem with VE trucks is blowing the tip of the FSS plunger apart and the truck not shutting off. I built my first one for my personal truck because my wife couldnt pull on my shut off cable hard enough to kill my truck  . Took the rubber off and welded the tip. Then chuck it up in a lathe and turn it down to .001 below the specs of the rubber tip. Ive built three more and they all perform exactly as the rubber tip plunger. I have video and pics if anyone would like to see.
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Re: Custom made FSS Steel plungers
Postby lz69 » Sat Aug 23, 2014 11:33 pm
Look like they would do the job, only thing I would worry about is if the steel plunger would eventually wear the aluminum housing. With that said I'm sort of surprised that someone hasn't tried making replacement out of nylon or teflon.
lz69
Postby oldestof11 » Sun Aug 24, 2014 6:01 am
The steel plunger would hit steel, not aluminum.
Postby therabbittree » Wed Aug 05, 2015 5:54 pm
I'm interested in buying 2 of your steel plungers.
Thanks ,
Deo
therabbittree
Postby dmerlin25 » Fri Apr 01, 2016 8:38 am
I would love to buy one of these off you. I don't have the PM privilege yet, but let me know how much or if there is something on my parts truck you want to trade for.
Never shoot a large caliber man with a small caliber bullet. Semper Fi
1993 W250 LE G360
dmerlin25
