Heater line cover
Heater line cover
Postby 92 D/UNIT » Thu Jan 04, 2007 9:50 pm
i dont know about you guys but im always trying to find or think of ways to make the eng compartment look a little better, built this heater line cover out of 14 ga. scrape that already had a brake in it so all i had to do was measure cut drill and paint. wish it was chrome, would like to come up with a way to cover the exh. manifold. any ideas?
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby whereswaldo250 » Thu Jan 04, 2007 10:26 pm
Looks awsome! Nice job IMO :lol:
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby swank » Sat Jan 06, 2007 8:14 am
i really like that thing, brian. i bet you could put it in the member endeavor section and get rid of a couple.
swank
Postby crossy » Sun Jan 07, 2007 7:09 pm
don't worry about chrome that will rust anyway. after you get your final build done then buy a sheet of thin stainless(not as costly as you think) and make one from that. you could always polish it a bit if needed, but as long as you don't beat it up in the benders it will look real nice. there is a guy at the Englishtown swap meets in Nj that is always selling half or quarter sheets ?? of POLISHED stainless cheap. crossy
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
Postby mhuppertz » Mon Jan 08, 2007 7:21 pm
I was thinking about doing the same thing, but for the purpose of getting better cab heat. Have you noticed better heater performance?
mhuppertz
Postby 92 D/UNIT » Mon Jan 08, 2007 7:27 pm
i have'nt noticed a difference, but my truck has always puts out good heat.
388/886
92 D/UNIT
Postby rlyons » Mon Jan 08, 2007 8:48 pm
What did you bolt it down to?
92 D250 Club Cab 4X2, 5 speed, ASA Modifieds Intake, Jannetty Racing Team Exaust System, Tweaked Pump, 3200 RPM Governor Spring, HTT Stage III Turbo w/16cm2 , Pyro/Boost/Tach Guages, Power Wagon Injectors, KDP Tabbed, Borgeson Steering Shaft.
rlyons
Postby 92 D/UNIT » Tue Jan 09, 2007 9:33 am
i used the existing heaterline bolts.
388/886
92 D/UNIT
Postby rlyons » Wed Jan 10, 2007 4:57 pm
That looks great, guess I know what my next project will be. :lol:
rlyons
