home made snorkle ?
home made snorkle ?
Postby 92 red cummins » Wed Jun 10, 2009 1:46 pm
I have been tossing around the idea of making a home made snorkle. pros: no risk of taking in water cons:hacking up fender and not liking end result,not getng enough air flow and losing power PS.I plan to keep the pipe in the fender except for the part that gos up towards the roof. Just wanted some opinions on the idea.
92 red 4x4 w250 dodge grille guard,KC lights,warn winch,hella fogs,advanced timing,k&n,
92 red cummins
Postby BobS » Thu Jun 11, 2009 3:23 am
I would not do this based on the fact it is never a good idea to immerse an aluminum bodied injection pump running at operating temperature into cold water. Also your power steering pump cap is vented which can let water enter.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby 92 red cummins » Thu Jun 11, 2009 7:28 am
thanks for the reply I tink I will just get acold air intake
92 red cummins
Postby Oddfire » Mon Jul 06, 2009 11:54 am
Remember gents, the Aussy's use them to keep there air cleaners from filling up with dust in there "normal" driving.
Oddfire
