Better heat
Better heat
Postby 12valve350 » Thu Dec 17, 2009 9:59 am
Well i havent posted anything since summer so, thought id show this little project i threw together .Image
Six in a row makes 'er go, Eight in a v, theres nothin' too see!
12valve350
Postby peobryant » Thu Dec 17, 2009 3:50 pm
Is not getting good heat a problem with 1st Gens? I've never had a problem with it, in fact Dallas usually tells me to turn it down after about 10 minutes. Or does this just make it get heat faster?
I love the front license plate. :lol:
Postby RumbleFish » Thu Dec 17, 2009 3:59 pm
my rig takes its sweet ass time about building heat. ive got half my grilel covered, and it was a noticeable improvement, but still need to cover the rest.
Postby PToombs » Thu Dec 17, 2009 6:45 pm
I like the license plate on the bent to siht bumper! ;) :lol:
My heat always works great! But then, I don't drive the truck when it gets much below 40*. :lol:
Postby 12valve350 » Thu Dec 17, 2009 6:47 pm
Well see thats where the honda bounced off me, she wears the scar proudly lol, i do need to change it though. I did that to get heat faster, and it works good
12valve350
Postby Ace » Fri Dec 18, 2009 8:38 am
Some type of winter front is a great idea if you need to drive in cold weather. I also made some grill inserts that helps it warm up quicker. I found that in really cold temps (single digits and below) the best thing is simply a piece of cardboard between the I/C and radiator. That blocks the air flow to the rad even better and allows cold air over the I/C. A 14" wide piece right in the midlle is all mine needs with the inserts at -10. But you have to be careful about remembering to take it out out before it warms up!
Ace
Postby dpuckett » Tue Jan 26, 2010 6:40 pm
I do what Ace did -just put a piece of cardboard in front of the radiator. It does raise the EGT in the 93 just a little- I figure the cold air isnt flowing like it would normally. I DO cut a small circle in the center (6-8" or so), just to keep some air going through.
Rumblefish- have you tried a new t-stat? I dont remember if I replaced it or not. I know all the rubber parts near it got replaced.
DP
Postby RumbleFish » Tue Jan 26, 2010 8:13 pm
i put a thermostat in it last winter. no change. it also seems that the blower isnt putting out as much air as i think it should. i dunno what else to do, maybe try to flush the heater core but ultimately i thin i might put one in as much as i dread the job. it does, however, make great heat with half the grill covered in 40 degree temps.
Postby 91cumminsd250 » Tue Jan 26, 2010 8:17 pm
wish i had heat, on a cold morning it wont get warm till i pull into skool lol
Chris make me a set of those
D250, Diamond Eye 4" exhaust, Denny T Stage 2 pin, Homemade intake, Boost/Egt gauges, too many window stickers
91cumminsd250
Postby 12valve350 » Fri Jan 29, 2010 1:04 pm
just put a bud light box on your radiator :lol:
12valve350
Postby doublel89 » Sat Jan 30, 2010 7:47 pm
empty 30 bomb works best :thumleft:
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
