New to Cummins
New to Cummins
Postby spullinjr » Thu Jan 24, 2008 7:39 pm
I've had enough of my whimppy K20 6.2L, and bought my first 12V to replace it.
Need some help with what I bought. I picked up a bus 5.9 6BTA with the air to water after cooler, is it worth keeping?
naturally the Air compressor has to go and a PS pump and Vaccum must come in, easy.
The Exh. Manifold is a questionable subject, not used to what I've seen in a 5.9L, it's turbo flange is perpendicular to the head rather than slanted on a dodge. I think I will jsut buy an after market and bolt it on and have the turbo to aftercooler bent.
The big one, I think, The tranny, was an Allison auto, 545?, I removed the tranny, t/C, and flywheel, and trans adapterplate. But the cranshaft end has a large cylindrical 2" protrusion from the end that I thought would support the back of the T/C from flexing? Is it part of the crank? non removeable? , do I need another crank to use the Chevy manual transmission adapter? I got it from a 4 bt bread truck to use on the NV 4500/ NP205 I already have? I dont plan to go HP on the diesal. Bottom line is this a all one piece crank? It has a VE pump, Just need some advice to get me started, All I plan to do is freshen up the engine, new oil pump, rings, bearings, clean, and valve Job, bronze valve guides. Help
spullinjr
Postby cummins king » Thu Jan 24, 2008 9:07 pm
you should post this in engine this part is for parts numbers,
so your saying you want to put the 5.9 into the chevy k20
check this sit out might help you
http://www.destroked.com/parts.shtml
93 4X4 auto
cummins king
sorry
Postby spullinjr » Fri Jan 25, 2008 11:41 am
Here are the Part numbers I have off the turbo and engine plate, can you tell me what all it means. I am going to us a 4bt bellhousing adapter, flywheel, and suck to the 6bta, then to GM gas early NV4500,
turbo assy #3523294, engine data plate #'s 359V, 6BTA 5.9, 5.9 B0856, 87.9,TDC 1.1,180 2500,, .010IN, .020IN, 612202-87, 153624, 3912468 5.9, 09/18/90, I 800-SPL.DI 44525536 60
spullinjr
air comp
Postby reneg8d » Tue Oct 28, 2008 7:13 pm
Jr, I'll gladly take the air comp off your hands if you still have it! Shoot me a pm with your location and what you need($) for it
Steve
reneg8d
