91.5-93 IC'd radiator rubber mount bushings/isolators
Postby bgilbert » Tue Jan 20, 2009 9:17 am
Mopar number 52027502, description: isolator. Cost was $5.00 8-14-08. Those rubber bushings/isolators that you see on top, and also on the bottom of the radiator on 91.5-93 intercooled trucks. These are also the same bushing used on 94-03 intercooler bottom mount bushings/isolators.
One can use them for either mounting a 91.5-93 intercooler or radiator in a nonIC'd truck.
Bill Gilbert
bgilbert
Postby oconnellrb » Tue Jan 20, 2009 8:02 pm
good to no info.
oconnellrb
Postby dpuckett » Wed Jan 21, 2009 5:22 pm
The rubber mounts are also the same if you install a 2ndGen intercooler in your 1stGen.
DP
