turbo to oil return tube gasket
Postby eyoung429 » Thu Mar 01, 2007 5:28 pm
anyone have a pn for these or what type of gasket material are you making them out of? I can't find one out here to save my life...
Thanks!
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby KTA » Thu Mar 01, 2007 5:47 pm
My local John Deere dealer has a drawer full of really nice ones, they fit like a 4430 Deere tractor and are a waxy kind of high heat paper, I have even been able to reuse them vs. destroying the paper cummins one. 8)
Postby bgilbert » Thu Mar 01, 2007 6:29 pm
Turbo oil drain gasket - 3937706
Bill Gilbert
bgilbert
Postby eyoung429 » Thu Mar 01, 2007 7:25 pm
Thanks Bill....btw...here's one of yours from last year that I just found :)
Valve cover w/oil fill - 3928405
Oil drain plug washer - 3920773
Intake cover plate gasket - 3938152
Grid heater gasket - 3938158
Valve cover bolt o-ring - 3928406
Valve cover gasket - 3930906
Exhaust manifold gasket - 3929881
Oil fill cap - 3901895
B Series tool kit - 3399869
Cummins screwdriver kit - 3400161
Non cycling thermostat - 3802968
Piston lift pump and parts needed for conversion:
- piston lift pump - 3936320 x1
- fuel line - 3914753 x1
- gasket - 3939258 x2
- spacer - 3914284 x1
- banjo bolt seals/washers - 3918191
Thermostat- Cummins ------------3802968
Thermostat housing (intercooled)- 3920353
Throttle rod (complete- i/c)-------4089076
front timing cover gasket----------3914385
Front main seal-------------------3804899
Cam follower gasket---------------3990732
Rear main seal=-------------------4089342
Vacuum Pump sseal kit (~$7.50)---4089742
Heater hose elbow (Gates)---------20388
Turbo oil supply line----------------3912747
Piston style lift pump (VE) ---------3936320
Fan hub assembly------------------3923004
fan hub bearing--------------------3910734
WIndshield Wiper bushings (HELP!)--49440
eyoung429
Postby Greenleaf » Mon Mar 12, 2007 9:34 am
I have some different numbers. This does not mean one is wrong or one is right. They have two or three part numbers for the same part. Trust me on this.
Fan Hub Bearing is Cummins 3910739
12 Valve non-cyle Thermo is 3934373
Call your dealership with your serial number when placing an order. It's nice to exchange info, however it does little good due to the frequent part I.D. number changes.
All you need is the serial. Unless you want items from another CPL. Then it's a crap shoot.
Greenleaf
tech specialist/mod
Postby CAJUN 93 » Mon Mar 12, 2007 11:21 am
if you have a mopar dealer closer than a cummins, order part#5003332ac
list price $1.76 plenty of stock available. shows 1989-2002.
daryl
CAJUN 93
Postby dpuckett » Wed Mar 28, 2007 4:27 pm
Or, in a pinch (I actually prefer it, though), you can use some anaerobic sealant. That stuff works great. Sets up almost instantly, and you dont have to worry about missing scraping every little bit of gasket material off and making a leak.
Daniel
