power steering pump attach bolts
Postby Ole' Blue » Tue May 10, 2011 11:03 am
Does anybody know the thread and length of the power steering pump attach bolts? There are 2 bolts that hold the pump to the engine, and the lower bolt is longer. Mine has backed all the way out and decided to start a new life on its own (it fell out). The dealer doesn't have any specs, and they can't get it for more than a week. Hoping to find it before that...
ps- if anybody's wondering, it runs and drives just great without the bolt! just leaks a bit of oil!!
'93 W250 Ext. Cab Flatbed Getrag. Tach, boost, EGT gauges. Fuel Screw bottomed out. 366 spring. BHAF. Tims Cooler Tubz. 3" dp to 4" exhaust. Work in progress.
Ole' Blue
Re: power steering pump attach bolts
Postby Ole' Blue » Tue May 10, 2011 4:38 pm
So I called another dealer... They gave me the info. It's a metric 12 x 1.75 x 35 bolt. The hardware store gave it to me for free :) Slightly less oil dripping from the bottom now! ;-)
Ole' Blue
Postby lvrider » Wed Sep 21, 2011 9:28 am
Im glad im not the only one with a leaky ps pump
1990 IC'd, POD injectors, 35 BFG MTs, 4inch straight pipe, 6" lift. BHAF mod...
lvrider
