2nd Gen Lift Pump New Part Numbers
Postby collegekid » Thu Jun 23, 2011 7:16 pm
So I figured if anyone wanted to install a newer 2nd Gen Lift Pump, I would bypass them having to go lookup part numbers for them, so these are the ones Ive found for the best price. I am not including the part number of the pump, as I already had one, but I have seen them on ebay for $25 used and $72 new. Here goes:
From Dodge (Mopar P/N)
Engine to Pump Gasket (2) - 5014230AB $3.45 each
Seals for Banjo Fitting on Fuel Line (2) - 5016555AB $2.00 each
From Case IH (Case P/N)
Spacer between Engine Block and Pump (1) - J914284 $10.70
New Hard Fuel Line (1) - J914753 $21.55
collegekid
