Dana 70 yoke, ujoint/strap kit, pinion seal part #'s
Postby bgilbert » Thu Oct 20, 2011 5:35 pm
Dana 70 1410 series yoke Spicer part number is 3-4-5711-1X.
U-joint Spicer part number 5-160X. Strap kit Spicer part number is 3-70-28X.
U-bolt kit for ujoint Spicer part number is 3-94-18X
Pinion seal Spicer part number is 42449. Side note on this seal, I went all around town looking for this seal, everyone had CR and other varieties of the seal. None were the quality of the seal I found from my local Spicer distributor. Plus they ranged from $16 and up versus the $6.73 for the Spicer seal. BTW the Spicer seal was a National seal. Also a D70 pinion outer race was the perfect size seal driver tool.
Bill Gilbert
bgilbert
Re: Dana 70 yoke, ujoint/strap kit, pinion seal part #'s
Postby ahale2772 » Fri Oct 21, 2011 4:07 am
cool thanks, ill be ordering some of them straps soon, and drilling :twisted:
Postby bgilbert » Fri Oct 21, 2011 9:33 am
These straps are not u-bolt style in case you were wondering. Get four new cap screws with the two new straps. I've not had any luck with NAPA, or Meritor brand straps in the past. I think as Philip once said in the past, the only thing good in the NAPA kit is you get four new bolts :lol: .
bgilbert
Postby ahale2772 » Fri Oct 21, 2011 11:01 am
oh :oops: i thought you were talking u-bolt style
i got the same spicer kit with the four bolts, they worked fine...so far
Postby Philip » Mon Nov 28, 2011 7:55 pm
I think as Philip once said in the past, the only thing good in the NAPA kit is you get four new bolts .
Yea I did. :lol:
Postby BCOWANWHEELS » Sun Dec 25, 2011 11:30 pm
I was told by a spicer rep that the reason spicer got away from u-bolts is because everybody tightened them too much and it was causeing u-joint failures " i diss-like the straps personally but what can you do " ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS
