Kick/Scuff/Sill Plate?
Postby ramtough1993 » Wed Feb 08, 2012 6:25 pm
I am trying to locate a place that makes the aluminum plate that is right inside of the door on the cab floor. The one that was on my truck was in three pieces in the tool box. Any body have any idea what i am talking about and where to get one?
1993 Dodge Power Ram 150 4x4, 5.2L Magnum, Automatic Transmission, Work Special Package, Currently mostly stock
ramtough1993
Re: Kick/Scuff/Sill Plate?
Postby CumminsPower59 » Wed Feb 08, 2012 7:37 pm
I know what you are talking about, try your local wrecking yard first, and go from there :thumright:
Postby RumbleFish » Thu Feb 09, 2012 4:28 am
I saw some NIB Mopar pieces on ebay the other day. I can't. Get you a link right now (stupid phone!) but if you do a search by seller, his username is smity2. I know him personaly, he's a good guy.
Postby ramtough1993 » Thu Feb 09, 2012 7:22 pm
Ok I'll have to try that, thanks guys, if this doesn't work I would have to check and see if the sill plates that are engraved with RAM and light up from a 3rd gen would fit.
ramtough1993
Postby PToombs » Fri Feb 10, 2012 6:35 pm
I bought some 2" wide aluminum stock at Home Depot to use on mine. Then I never did put it on, I pull the mat back all the time to make sure the floors are dry. The rubber door seal never moves anyways, so why bother?
Postby bmoeller » Fri Jul 04, 2014 8:13 am
LMC sells the sill plates now.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby PToombs » Fri Jul 04, 2014 5:57 pm
Yeah, they're only 50 or 60 bucks a pop. :shock:
