Spicer U Joint part #'s for every joint on a W250?
Postby Bookshelf » Sat Sep 29, 2007 9:51 am
I was wondering if anyone had a # for every joint, front and rear driveshafts and steering knuckle. Thanks for any help.
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby Makaio » Thu Nov 29, 2007 10:39 pm
Well..... the Spicer u-joints are 5-160X and the NAPA numbers are 210-0160. Sorry, I don't have the front numbers.
Aloha,
Matt
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby CAJUN 93 » Fri Nov 30, 2007 7:50 am
i dont know if this helps but the oe number for a 7290 joint is #4504575
list $50.25 ea, trade $40.20 ea
as a btw, the factory 7290 joint show without a grease fitting, the 7260 has one.
daryl
CAJUN 93
Postby BC847 » Sun Dec 16, 2007 8:09 am
There are a few options for the Spicer wheel joints:
Forged with zerk-SPL55-4X
Forged w/o zerk-5-806X
Old school cast 5-332X
Postby bgilbert » Tue Dec 18, 2007 12:18 pm
How about the carrier bearing? Is this a Timken/Napa/etc bearing or is there a Spicer carrier bearing available?
Edit: Spicer carrier bearing for 1st gen 2 piece drive shaft be it 5 speed regular cab 2wd or extended cab long bed is: 210140-1X. Was about $45 vs. $61 for NAPA version.
bgilbert
Re: Spicer U Joint part #'s for every joint on a W250?
Postby ofelas » Mon May 04, 2015 4:40 pm
Front axle - Spicer Life SPL-553-X two
Front shaft - Front Joint - Spicer Life 5-811X one
Front shaft - Center & Rear Joint - Spicer Life 5-795X - one each
Front shaft CV Joint kit - Spicer Life - 211009X - one
Rear shaft - Front & Rear - Spicer Life 5-811x two
R12 = liquid bilit
ofelas
Postby Bookshelf » Tue May 05, 2015 7:45 am
ofelas wrote:Front axle - Spicer Life SPL-553-X two
Where were you able to get those numbers? And are the front numbers from 93 or earlier. I have found 93's have at least a bigger joint at the front driveshaft to diff joint, not sure about the cv
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby ofelas » Tue May 05, 2015 7:55 am
Hi I called Spicer (Dana) and got those numbers for my 91.5
R12 = liquid bilit
ofelas
Postby Collers9640 » Sat Sep 19, 2015 8:42 pm
I was doing some research on the 5-811x part number and found that the cup size is 1.126 when I went out and measured some on an old 2wd drive I have out back I got 1.188.
So I checked out the Dana spicer site and found the at the diesel size is 1.188 for the three rear drive shaft u-joints.
So the part numbers are like this
5-811x. 1.126 -wrong size. (I'm sure it's fits but would be loose and sloppy)
Spicer #. 5-160x 1.188
Spicer Life # 5-1410x. 1.188
Here's the link to check it out
http://www2.dana.com/expertforms/dek350.aspx
Collers9640
