4wd Indicator Switch
Postby Collers9640 » Tue Aug 05, 2014 2:18 pm
Anyone know if there still made or will I have to splice in a modern one
Collers9640
Re: 4wd Indicator Switch
Postby CumminsPower59 » Tue Aug 05, 2014 7:58 pm
Unless you got $100-150 burning a hole in your pocket, you'll be hard pressed to find something else that will work. Quad 4x4 has both styles available...the factory blade connection type ($150) and an updated version that uses a GM style weatherpack connection ($110).
Postby Collers9640 » Thu Aug 07, 2014 8:53 am
There's no way I'm dropping $100 bucks on it. Half the threads snapped on so I think I'm just gonna screw in what's left and tack weld it. Thanks for info
Collers9640
Postby Collers9640 » Tue Jan 20, 2015 4:25 pm
Well there was enough thread to get the switch seated so I tac welded it in
Works Great!
Collers9640
Postby CumminsPower59 » Wed Jan 21, 2015 11:00 am
Good deal :thumright:
