Double Cardan CV Joint, Front axel
Postby BradPA » Tue Mar 05, 2019 10:08 am
I broke my Stock Double Cardan CV joint.. both Flange and H part. shaft with ball on end may work if i have to rebuild.. cup where ball fits against shaft was tore up..
So i looked up a new one ...
I have the dana 60 , 4500 front axle ..205 transfer case, 5 speed manual trans
OOboy A1 Cardone part number 659327 looks to be what i want... but these are not in stock or available right now.
So any ideas .. or where I can find a rebuild able one..
My truck Thanks you in advance.... :D
Brad
1991.5 - Dodge W250
BradPA
Re: Double Cardan CV Joint, Front axel
Postby thrashingcows » Tue Mar 05, 2019 7:34 pm
Take a look at car-part.com, they link 1000's of junkyards and wreckers.
thrashingcows
Postby BradPA » Wed Mar 06, 2019 5:51 am
thanks ..
i checked them out and many others
car-parts list 2 complete axles for a Dana 44 .. they also list the flange and H part..
I think the length is the key, with a 5 speed, D 60 and 4500 front end and a 205 transfer is (24 3/4)
if i buy parts plus u joints and try to rebuild using my axle shaft with tore up cup .. sounds like a waste of time .. and may not work ..
on the axle shaft there's a tin cup tack welded on end this is where the ball seats. this is tore up and ball may not seat right or hold grease.. So the last week i have been doing searches and info
the Cardon 659327, looks to be correct replacement i need .. and from what i see they may make a run of them sometime this summer.. i have to wait and see
Hey Thanks again...
BradPA
Postby thrashingcows » Wed Mar 06, 2019 2:27 pm
IS there any reason you can not take your broken drive shaft down to a driveline specialty shop locally and have them build you a new one?
thrashingcows
Postby BradPA » Wed Mar 06, 2019 4:05 pm
Hey good News.. they are or will be making some soon expected ship date middle of next month..
so i ordered one,,, thanks again...
its total cost,, i would still need H and flange ,, u joints...and CV its self then fix the shaft..
i just have to remember that there are 3 grease fittings that need my attention. not 2 :D
BradPA
