my 1st gen part numbers list......
Postby LOGANSTANFORTH » Sat Jan 26, 2008 9:55 pm
Moog part numbers for 1st Gen 2wd and 4wd trucks.
93-88 2wd truck numbers:
centerlink DS1173
adjusting sleeve ES3124S
right outside tierod ES3122R
right inside tierod ES3123L
left inside tierod ES3123L
left outside tierod ES3122R
idler arm K7055
upper balljoint K778, K7082(HD)
lower balljoint K7025(must replace with K727 if it has 4 wrench flats and is screw in), K7025T(enhanced design), K7053T(HD)
upper control arm shaft kit K7036
upper control arm bushing kit K7006(2 required per truck), K7189(1 kit per truck, performance busings), K7104(eccentric bushing kit for more camber)
upper control arm bumpstop K7293
lower control arm bushing kit K7077(2 kits per truck), K7193(1 kit per truck, performance bushings)
HD lower control arm bushing kit K7065(2 kits per truck), K7192(1 kit per truck, performance bushings)
lower control arm bump stop K7282
sway bar to frame bushing K7096
sway bar link repair kit K7081
rear leaf spring bushing 1" O.D. x 1/2" I.D. SB266
rear leaf spring bushing 1 1/2 O.D. x 3/4" I.D. SB268
93-88 4wd truck numbers:
upper ball joint K8194T
lower ball joint K8195T
bump stop K7282
lower kingpin K992(provides 1 1/2 degree of camber adjustment)
lower kingpin bearing kit K8832
upper kingpin bearing kit K6652
sway bar to frame bushing with 1 1/16 bar K7302
both sizes are thermoplastic bushings
sway bar to frame bushing with 1 3/16 bar K6172
swaybar link repair kit K7081
right tierod ES2010R
left tierod ES2010L
draglink DS914
adjuster tube DS1411S
front leaf spring bushing front and rear SB266
FEL-PRO engine gaskets and seals
head gasket 9332PT
head set w/o gasket HSU9332
gasket conversion set CS9332 (includes oil pan gasket)\
exhaust manifold gasket set MS92089
exhaust pipe gasket 60928
oil pan gasket OS34102
rear main seal and gasket set BS40633
valve cover gasket set VS50396R
pushrod cover gasket set PS50397R
valve stem seal SS70819-1
water outlet o-ring 35526
water pump gasket 35525
timing cover gasket TCS45902
anchor industries motor mounts
2wd
front motor mount 2710
tranny mount N/A
4wd
trans upper mount 2667
trans lower mount 2668
Carlson Brake Part Numbers
D250 w/ 12x2.5 drum
front
disc hardware kit H5516
pad shim kit 18063
caliper repair kit 41099
bleeder screw H9402
caliper piston 7535 for phenolic, 7501 for steel
caliper support spring H5315
inner bushing H5209
rear
drum hardware kit H7199
brake drum pro kit H2316
guide pin H4087
bolt sleeve H547
adjustment screw spring H430
self adjuster repair kits H2598 left, H2599 right
wheel cylinder repair kit 45004
hold down pin H1119
hold down spring H1164
adjuster lever H2049 left, H2048 right
cable guide/pivot H2093
cable H2104
lever return spring H2140 left, H2141 right
adjuster screw assembly H1534 left, H1535 right
D350 w/ 12x2.5 drum
front
pad shim kit 18063
bleeder screw H9402
inner bushing H5209
rear
guide pin H4087
bolt sleeve H547
wheel cylinder repair kit 45004 for 7/8" wc bore, 45002 for 1" wc bore
hold down pin H1119
cable H2104
D350 w/ 12x3 drum
front
pad shim kit 18063
bleeder screw H9402
inner bushing H5209
rear
guide pin H4087
bolt sleeve H547
wheel cylinder repair kit 45002 for 1" wc bore, 45019 for 1 1/16" wc bore
hold down pin H1119
cable H2104
Four Seasons Temperature Control Products
system specs R-12, refrigerant capacity 44 oz., oil capacity 4.6 oz for 93, 7.25 oz for 92-89
blower motor w/ A/C 35474
blower motor w/o A/C 35560
93-92 SDB709 type compresor w/ clutch S57562
91-89 C171 type compressor w/ clutch 57106
non-intercooled condenser 53298
intercooled condenser N/A
evaporator core 54108
expension valve/orifice tube 38849
intercooled fan clutch 36936
non-intercooled fan clutch 36705
filter drier/accumulator 33555
heater core w/ A/C 94619
heater core w/o A/C 94600
93-90 tensioner assembly 45844
89 idler pulley 45981
clutch cycling switch R-12 35800
clutch cycling switch R-134a 36677
coolant temp sensor 36425
low pressure cut out 35752
water outlet 85181
Tranny Coolers
Ultra-Cool
light duty 53000
medium duty 53001
heavy duty 53002
Rapid-Cool
light duty 53005
medium duty 53006
heavy duty 53007
Modine Radiators, Condensors, Heater Cores
specifications
core size 25 3/4 x 21 x 2 1/4 (3row)
inlet header 2 5/8 x 21 1/4
outlet header 2 5/8 x 21 1/4
inlet connection 1 3/4 left
outlet connection 2 right
pin mount
93-92 radiator 2460
93 condenser 300034
92-90 condenser 300031
89 condenser 300025
heater core 702463, 702464
heater core specifications
702463: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is beside core
702464: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is above core
I COLLECTED AND TYPED ALL OF THOSE AND THEY ARE AS ACCURATE AS I CAN POSSIBLY MAKE THEM........
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby cummins king » Sat Jan 26, 2008 10:59 pm
nice job wish i had some of them sooner
93 4X4 auto
cummins king
Postby LOGANSTANFORTH » Sun Jan 27, 2008 8:43 am
yeah ive been wanting to join just never did, i got them posted on all the other sites just not here.....
LOGANSTANFORTH
Re: my 1st gen part numbers list......
Postby jeff77indy » Fri Apr 09, 2010 4:05 am
Anyone have the P/N for the springs that are used with the king pin bearing/bushing kit? When I did my '89 W250 I bought the kits from Dodge and one side had springs for which replacements were in that respective kit.
The Moog P/N's above do not show the spring included.
Thanks
Jeff
jeff77indy
Postby ofelas » Mon May 04, 2015 4:37 pm
Heres some more...
Capacities
Engine oil - 12 quarts with filter EaO80 (Donaldson ELF7349), Wix 51607, Fleetguard LF16035, Mopar
Cooling - 17 quarts
Tranny - 11 quarts dry, Wix filter 58707, Hastings TF42, ATP B-42. Mopar 3515996 + Mopar gasket 2464324AC
Transfer case - NP205 - 2.2 quarts
Front Dana 60 - 3.3 quarts
Rear Dana 70 - 3.5 quarts
Sure Grip - 4oz
Fuel filter - Wix 33379, Mopar 4429107, Cummins FS1232 (integral drain valve - Wix 86472, Fleetguard FS1221, Baldwin BF1221)
Fleetguard FH-23510 Diesel Pro heater/filter/separator
Air filter - Wix 46343, Fram CA6629, Baldwin PA2183, Fleetguard AF4555M, Mopar 4428325, Donaldson P530355, AFE Pro Dry 11-10031, Amsoil LT S1525 oiled foam
SENSORS
Oil pressure - 2 prong Cummins 3923200, Mopar 53030493, Standard PS233, ECC 53-33572
Thermoswitch - Cummins 2 wire 3408645/4327029
CTS - Cummins single wire 3920363
Starter relay - RY607
OD solenoid - TCS54
TPS - TH245
Crank position sensor - Cummins 3924432
Intake air temp sensor - Cummins 3918461
WIF sensor - Fleetguard 3831852-S
ELECTRICAL
Battery NAPA BAT 7235 (1125cca) or 7237 (950cca) Optima D31A (900cca), Deka 8A31DT/M (800cca), Mopar BB31A950AA (950cca), CQ 31P30 (950cca)
2/0 ring terminals 3/8” hole - Grote Orange 84-9110 or 84-9309 locking
+ve - 12, 12, 16, 6, 2/0
-ve - 8, 2/0
Alternator upgrade - Denso 211-0129 new or 210-0151 reman 136 amp (90 amp idle)
Voltage Regulator - BWD R296
Grid heater solenoid Stancor 120-901
FUEL
Fuel heater seal - Cummins 3913695
Lift pump gasket - Cummins 3939258
Shut-off solenoid - FS15
ENGINE
Serpentine belt - Gates K080635 or K080635HD Fleetrunner, Mopar Q408640, Gatorback
Dayco Poly V - 5080640 (Cummins V 3926866)
Tensioner & pulley - Gates - 38157 Dayco - 89219 (Cummins - 3912254)
Oil drain plug & gasket kit - Cummins 3973071 - 18 x 1.5 x 12 OEM with 3/8” socket
Oil pan - Cummins 3914403
Oil drain tube Cummins 3918585
TRANSMISSION
P5249641 Mopar RWD Shift Improver Package 90-95 A-518
Transgo TFOD-518 or TFOD-DSL
BRAKES
PFC Carbon Metallic pads 0149.20 (Z-rated 0149.10)
Wagner semi-metallic pads severe duty SX149
Raybestos semi-metallic severe duty pads PG-D149M
DRIVELINE
Locking Hubs -
Yukon Gear YHC70003 $370 all steel
Mile Marker Supreme 449SS $170 all steel
Warn Premium 38826 $270 aluminum (overpriced junk)
U-JOINTS
Front axle - Spicer Life SPL-553-X two
Front shaft - Front Joint - Spicer Life 5-811X one
Front shaft - Center & Rear Joint - Spicer Life 5-795X - one each
Front shaft CV Joint kit - Spicer Life - 211009X - one
Rear shaft - Front & Rear - Spicer Life 5-811x two
SHOCKS
Front Bilstein 5100 - BIL-33-185590 (0-2”) Mount sticker up
Rear Bilstein 5100 - BIL-33-185569 (0-2”) Mount sticker up
COOLING & HEATING
180 bypass thermostat NAPA/Gates 33758, Cummins 180 thermostat 5292738/3972071 seal 3923331; Cummins 3802968 complete kit
Fan clutch Mopar 52028760, Hayden 2798, updated Mopar fan 52028653
Water pump & O-ring Gates 41181
Upper rad hose - Gates 21930, Dayco 71594
Lower rad hose - Gates 20431, Dayco 71595
Molded 90 degree heater hose - Gates 20338
Straight silicone heater hose - Gates 26241
ACCESSORIES
Y155 ignition & door lock key from 1993 or Y154 from 1989-1992
Throttle return spring Dorman 59209
TST-KDP04 - Killer Dowel Pin Repair kit bent tab
Vacuum pump seal kit - GD-GGO3XP-VPSK
Autometer column cover single gauge pod ATM-15012
Autometer dual A-pillar gauge pod ATM-15198
Autometer Z-series pyrometer kit - ATM-2654
Autometer Z-series 0-35 boost kit - ATM-2616
Isspro tach 8503/adaptor 8912-92
Ventshade 92031
R12 = liquid bilit
ofelas
