2nd gen flexplate part # ?
Postby DLittle » Thu Jan 04, 2007 6:53 pm
I'm going to be putting in a new Suncoast torque converter :D and I need the part # for the 2nd gen flexplate ?
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby Greenleaf » Fri Jan 05, 2007 6:03 am
Cool...here you go.
Cummins 3946161
Greenleaf
tech specialist/mod
Postby DLittle » Fri Jan 05, 2007 8:32 am
Thanks I'll get one ordered.
Dana
Dana
DLittle
Postby Greenleaf » Fri Jan 05, 2007 9:45 am
I recieved mine from PDR. It's a SFI unit. I still have the part number. It was 150.00. You can order the Cummins brand part from reliablegoods for like 75.00
Greenleaf
tech specialist/mod
Postby KTA » Fri Jan 05, 2007 2:21 pm
If you want one that will never break regardless of power for competition type use you can go with the ATS billet flexplate. I helped on the design and clearance of that plate and it is a sweet piece. There is nothing else like it out there, it is basically a flywheel for a torque converter. :D
Postby TOMTOM » Sat Jan 06, 2007 8:19 pm
I have one from a 06 will it be of benefit on my 93?
are the 2nd gen's stronger?
KTA glad to see you here. Very impressed with OLD YELLOW!!!
93 CLUB CAB LE SHORT BED 209,000 MILES AUTO/OD 3.54 GEARS 4" TURBO BACK EX NO MUFFLER P7100 PUMP MODS B/D INJECTORS 13.55@99 MPH 440HP 967TQ ON #2 ONLY. PSD INTERCOOLER,BD SUPER B TURBO)47RE FULL MAN SUNCOAST TRIPLE DISC
TOMTOM
Postby BC847 » Mon Jan 08, 2007 4:08 pm
KTA wrote:If you want one that will never break regardless of power for competition type use you can go with the ATS billet flexplate. I helped on the design and clearance of that plate and it is a sweet piece. There is nothing else like it out there, it is basically a flywheel for a torque converter. :D
The folks at ATS told me the billet model will not fit my '93. It's too tall in profile compared to the OEM. If I understood correctly, it's related to the differences in the lock-up/non-lock-up converters. :?:
Postby KTA » Mon Jan 08, 2007 5:27 pm
The bIllet is a VERY tight fit on the 2nd gens, so maybe it wont fit the old non lockup TC??? I dont see why it wouldnt though cuz if a 2nd stocker will work, why wouldnt the aftermarket?? The only thing I can think of is the stamping of the OEM converter must have interference. I am not an auto guy myself so I would just have to take their experienced word for it that it wont work, maybe someday when I have one out I'll try it for myself and see. :)
Postby TOMTOM » Tue Jan 09, 2007 7:15 pm
1ST GENS USE DIFF BLOCK TO TRANS ADAPTOR(THINNER) MUST BE CLOSER INSIDE. ARE THE TOOTH COUNT THE SAME?
TOMTOM
TOMTOM
Postby JD730 » Thu Feb 08, 2007 1:56 pm
TOMTOM wrote:1ST GENS USE DIFF BLOCK TO TRANS ADAPTOR(THINNER) MUST BE CLOSER INSIDE. ARE THE TOOTH COUNT THE SAME?
TOMTOM
Its thinner, yes, about an 1" thinner than a 2nd adaptor, but thats because there is no lockup clutches in the converter to make it thicker. Tooth count is the same and the clearance inside is close to start with.
I'll look at my non-lockup converter, maybe KTA is onto something with the stamping interference.
Mike
The "Rattle Box"
JD730
Postby dpuckett » Fri Feb 09, 2007 11:33 am
Didnt ATS also say their 12v manifolds wont work on a 1stGen? :roll: Might not hurt to get a second opinion. Of course, it also depends on who you talk to on the phone- a real technician, or just a sales person.
Daniel
Postby bgilbert » Sun Apr 15, 2007 10:56 pm
Pulling buddy of mine, 518 non lockup, has a ATS flexplate in hand, says it will not work. I think he said it wouldn't clear the convertor :?: . I can't remember. Not sure what route he should go with, some SFI unit or the 2nd gen Cummins flexplate? Built engine, 800hp :twisted: :!: :wink: ...
Bill Gilbert
bgilbert
Postby KTA » Mon Apr 16, 2007 6:26 am
If you are going to pull 800hp you better get a lockup tranny or your pissing in the wind.
Postby bgilbert » Wed Apr 18, 2007 12:10 am
KTA wrote:If you are going to pull 800hp you better get a lockup tranny or your pissing in the wind.
"Oh but the gassers been running 727's for years with no lockup".... That's what he says.. or wants to believe the 518 will work. He's looking for a 47rh or nv4500.. no luck. Probly the only reason he hasn't pooped it out on the track is he hasn't made much HP yet with all that HOT air, non-intercooled style. Ag gov p-pump, Jim Jessup specials :roll: :lol: (370's), and Pro52. He's got a s400 on the way from his pump guy in Southern Indiana and still not sure about injectors. Nice side track there.
bgilbert
Postby KTA » Wed Apr 18, 2007 11:16 am
You can't break it if you cant put any power through it. 8)
