lp part number
lp part number
Postby ahale2772 » Sun Oct 04, 2009 7:27 pm
Ive got a couple of questions, Im sure u guys have been asked this a million times but dose anyone know the latest most up to date partnumber for the 15 psi lift pump, I had a cummins guy crossreference an older pn (3936320) and he came up with the 30 psi pump, i thought about using that with a pressure relief but im gona just try to get the right one instead....unless anyone thinks this is a better way to do it....
, also can any one who has put one of these on a 1st gen tell me how u cut the insulation off of the crank case breather tube thingy?
,and lastly when I was mocking up the 2ng gen 30 psi pump to my motor I noticed that the rod exctinding to the cam looked a little low in comparison to where the cam was located (the pad that contacts the cam was far below the center of the cam) and even with the spacer for the pump i dont trust putting this pump on and breaking something im sure Im just being paranoid but Id love a second opinion,
thanks in advance
Postby Ace » Mon Oct 05, 2009 7:46 am
The "best" way to deal the crankcase insulation is to leave it alone. The stock filter is a bottleneck. Not just the filter, but the passages in the manifold as well. Get a fuel filter head, mount it to the frame and run a bigger filter with at least 3/8" line all the way through. Then you just thread the fitting of your choice into the top of the pump and be done with it.
Ace
Postby ahale2772 » Mon Oct 05, 2009 9:02 am
the filter? why would i change that ? where is the filter in relation to the insulation? dose it block the line or the fitting?
Postby Ace » Mon Oct 05, 2009 10:46 am
The line running from the piston pump to the stock filter is why you have to clearance the block insulation.
Ace
Postby ahale2772 » Mon Oct 05, 2009 3:03 pm
yeah i was actually planning on using my own line i dont feel like spending 40 dollars for the cummins part so my clearence issues are minimized but im guessing if i cut off 1/4 of an inch id be fine have u ever seen anyotne trim the insulation?
Postby PToombs » Mon Oct 05, 2009 6:28 pm
Just trim the insulation with a utility knife. It has a hard cover but cuts ok.
Postby ahale2772 » Mon Oct 05, 2009 8:25 pm
okay i havent busted into it yet and i just wanted to know what i was gettin into before i go at it rambo style
Postby mprmn08 » Tue Oct 06, 2009 5:24 pm
its very easy. just take your time and do it right the first time. i did it a while ago and it all went well. took me a short afternoon but i was takin it slow as i never did it or seen it done before.
mprmn08
Postby ahale2772 » Tue Oct 06, 2009 5:39 pm
yup thats the plan anyone know what im talking about when i say the rod sticking into the cam on the piston pump looks like the wrong angle?
Re: lp part number
Postby jhedge » Fri Mar 12, 2010 11:35 pm
I might be a few months late here but you probably had the right pump. Assuming your Cummins guy found part number 4988751, that pump is listed in the Cummins system as a 30 psi pump but that's sort of a typo. If you look at the top of the body of the pump (just below the outlet) you should see a dot. As long as that dot is violet, you have the right pump. Blue, green, red, and no dot are all 30 psi pumps.
jhedge
