DODGE CUMMINS ALTERNATOR CROSS REFERENCE PART NUMBER 1989-93
Postby BobS » Sat Jan 30, 2010 5:02 pm
The following are part number cross references for the factory alternators used on 89 - 93 Dodge trucks with Cummins engines:
1989
120 Amp External Regulator, Battery Terminal 4:00
Cross References:
Bosch AL587X
Chrysler 5233599, 5233608, 5233651, 5233660, 5234651
Delco 10459532, 10463809, 321-1222, 334-1103, 334-1104, 334-1105, 334-1846
Denso 121000-4000, 121000-4010, 121000-4030, 121000-4090, 210-0134, 210-0137, 210-0138, 210-0139, 9712109-400, 9712109-401, 9712109-403
Dixie A8234, A8699, A8700
Lester 13223, 13264, 13280, 13304, 13308, 13313
PIC Picture ID 290-266, 290-267, 290-267A, 290-267C
Rayloc 13-8316, 13-8318, 13-8319, 213-8319
1990 1991 1992 1993
120 Amp, External Regulator, Battery Terminal 4:00
Cross References:
Bosch AL6510X, AL6526X
Chrysler 5234033, 5234053, 5234199, 5234206, 5234208, 5234260, 5234374, 53008651, 56005686, 56027221, 56027913
Delco 10459507, 10463829, 10463830, 10463831, 10463833, 10463836, 321-1242, 321-1243, 321-1244, 321-1246, 321-1249, 334-1294, 334-1298, 334-1957, 334-1958, 334-1959, 334-1960, 334-1962, 334-1967
Denso 121000-4040, 121000-4050, 121000-4060, 121000-4070, 121000-4080, 121000-4120, 121000-4130, 121000-4150, 121000-4151, 121000-4170, 121000-4171, 210-0133, 210-0146, 210-0147, 210-0148, 210-0149, 210-0150, 210-0151, 210-0152, 211-0121, 211-0123, 211-0124, 211-0125, 211-0126, 211-0127, 211-0128, 211-0129, 9712109-404, 9712109-405, 9712109-406, 9712109-407, 9712109-408, 9712109-413
Dixie A8265, A8659, A8660, A8698, A8701
J&N 400-52043, 400-52044
Lester 13301, 13302, 13309, 13310, 13311, 13742
PIC Picture ID 290-255, 290-261, 290-261A, 290-262, 290-264, 290-265, 290-265A, 290-5103, 290-5110
Rayloc 13-8600, 13-8601, 13-8602, 13-8608, 13-8609, 13-8612, 13-8615, 13-8625, 13-8632, 213-8608
This is catalog information for factory original equipment replacements from when I was an alternator rebuilder. Use at your own risk.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby Richie O » Sat Jan 30, 2010 5:40 pm
Was it only the 89's that had the chrysler style alt? Does not all the rest have the nippo unit?
Postby BobS » Sat Jan 30, 2010 6:13 pm
I think 89 was a 'Denso with a Chrysler part number tag. Apparently this must be some small difference between the newer ones.
As additional info the 94 Cummins also has the same interchange numbers.
BobS
89 D350 Stock
BobS
Postby Richie O » Sat Jan 30, 2010 6:51 pm
Not sure. I know my 93 alt is a nippo and my 89 is the delco shaped chrysler unit. My 89 FSM has the nippo listed as 5233599 and the chrysler unit is 5233199. I remember when I did the alt a few years ago on my other 89 they asked if it was a nippodenso or chrysler.
