74 W300 gasser pulling vid
Postby bgilbert » Fri Jul 23, 2010 2:15 pm
Here's my first ever hook, for the truck and myself: http://www.youtube.com/watch?v=kPGHCobt3cM
It's a 74 Dodge W300 cab and chassis dually truck that I put a single wheel pickup bed on. It's got a 135" wheel base, 4" longer than a pickup. 360, holley 4 barrel, 4 speed and stock clutch, 4.88 gears, dana 70's front and rear. I think the rings might be bad, as you can see it had a nice oil smoke plume out the back. It also blew the dipstick out and a little bit of oil under the hood and on the intake. I also let out of it at the end, I think it might have had another foot or so haha. I looked out my mirrors as the truck was slowing down and seen all the white smoke. I thought it was the bed coming down on my tires, I figured well they're on fire I better let out :lol: . At the end of the video you can see how far back the rear axle sits from the longer wheel base. I had fun and will do it again.
Bill Gilbert
bgilbert
Re: 74 W300 gasser pulling vid
Postby pulltilbroke » Fri Jul 23, 2010 6:23 pm
Not bad at all for your first hook!!!
Postby JBradley500 » Sat Jul 24, 2010 3:44 am
man i wish i would have went to paris. jobs really get in the way of having a good time.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby GO OVRIT » Sat Jul 24, 2010 11:35 am
I wish I had a video of my 74 w300 440 truck hooked to the sled. It would be a good laugh. I think you could've hook yours to my truck and the sled an still pulled farther. The engine I'm putting together now should do a little better.
GO OVRIT
Postby bgilbert » Sat Jul 24, 2010 4:36 pm
Thanks guys. Your 440 truck didn't pull it out the gate? :lol: Are you building a Mopar engine? After seeing a 396 Chevy in a 74 W200 and then everybody and their brother around here telling me how easier and cheaper it would be to build a big block Chevy, it's got me thinking..
Bill Gilbert
bgilbert
Postby pulltilbroke » Sat Jul 24, 2010 7:40 pm
Don't put a Cheby motor in there, I'm a Chevy guy but thats just sacreligous putting a Chevy in a Mopar.
Postby 1STGENFARMBOY » Sun Jul 25, 2010 5:21 am
What is all this talk of gas motors??? $1000 you could have a ( D I E S E L )
Postby Richie O » Mon Jul 26, 2010 3:08 pm
I like the gasser pulls just as much. I like it. :D A guy up here has a 71 chevy that is just for pulling. He reved it up so high and dumped the clutch that the headlight popped out and was hanging by the wires. :lol: I keep wanting to do a gasser truck just for play. Add it to the " want " list.
Postby bgilbert » Sat Jul 31, 2010 12:00 am
Second pull for the truck and driver. Did a little better this time. 290 something feet. Didn't catch the standings but Nicole said there were at least four trucks that didn't go as far as I did 8) . http://www.youtube.com/watch?v=T7J9ONiOZPA
Bill Gilbert
bgilbert
Postby bgilbert » Sat Jul 31, 2010 12:12 am
Here's a twin to my truck, as far as the engine, trans, t-case, axles and gearing: http://www.youtube.com/watch?v=8nUawbsaSv4 .
It's another 74 W300 cab and chassis truck. 2 barrel carb though :oops: . Evidently his clutch won't hold 2nd gear low range, so he pulls in 1st gear low range.
bgilbert
Postby KTA » Fri Aug 06, 2010 6:47 pm
I did some pulling last week too. Its a 466cid 3000 rpm hot farm Deere. It spins out road gear in the 10000lb class, this was the 13000lb hook. The injection pump developed a governor problem that hook(pieces came loose) and made it want to hunt and that started it bouncing some. Still managed the win by 8foot on a very competitive class. :D
The video
http://www.youtube.com/watch?v=zDHSzj7fJcI
Postby Richie O » Fri Aug 06, 2010 7:28 pm
That thing had some ground speed. :shock:
Postby KTA » Fri Aug 06, 2010 7:57 pm
Wheel speed is right at 25mph.
Postby bgilbert » Sat Aug 07, 2010 7:14 am
That looked awesome Brian. Now everyone sees what you've been doing while waiting for someone to knock you off your high hp chair :lol: !
bgilbert
Postby KTA » Sun Aug 08, 2010 9:06 am
Thats funny Bill. I think this tractor is only about 1/1000th of the diesel related projects I have going on. I hooked it again last night and won by 20feet. :D Its kind of fun going 300+feet without the front wheels ever touching the ground. Sorry there are no videos though that I am aware of. I think a max wedge 440 with 2 650 holley 4bbls should wake that rig of yours up. :grin:
Return to Competition
