Weight
Weight
Postby redneckroot » Thu Aug 05, 2010 9:07 pm
We have been tossing the idea around of a purpose built pulling truck. If we build one we'd like to stick to the 1st gen body style. What I'm looking for are the known weights of the different trucks. I know my regular cab ctd is roughly 5700. Does anyone know what a W350 extended cab is? Or a 4 door long box?
redneckroot
Re: Weight
Postby Ram360man » Fri Aug 06, 2010 12:32 am
My reg cab aluminum flat bed weighs around 5700. A ex friend has a 92 W250 ext cab that weighed 6700. Its a farm truck though so it had a tool box and a bunch of crap in it. Probably weighed about 63 or 6400 empty.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: Weight
Postby redneckroot » Fri Aug 06, 2010 8:32 pm
Thanks for the reply. Does anyone know what a w350 extended cab weighs?
redneckroot
Re: Weight
Postby meby » Sat Aug 07, 2010 6:30 am
My dad's W350 regular cab(single rear wheel) weighs 6500. My D250 regular cab weighs 5500 with me in it.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Weight
Postby KTA » Sat Aug 07, 2010 7:02 am
A dually w350 extended cab should weigh about 6300lb empty.
Re: Weight
Postby redneckroot » Sat Aug 07, 2010 8:47 pm
Anyone have pictures or know of anyone with a w350 extended cab puller? Thanks for the reply's hopefully we can locate a truck cheap enough with a good 4x4 frame and sheet metal.
redneckroot
Re: Weight
Postby KTA » Sun Aug 08, 2010 8:58 am
The Moonlight diesel truck more or less is a single rear wheel version of a w350. Its the slickest looking 1st gen puller I know of, and of course the body of it is about the only thing left that is 1st gen.
Re: Weight
Postby redneckroot » Sun Aug 08, 2010 7:37 pm
That truck runs really good from the video's I've seen. Are they still running a stock style frame or is it a tube deal? Any idea what year/model ford truck had the dana 60 with the pinion on the driver side?
redneckroot
Re: Weight
Postby KTA » Sun Aug 08, 2010 7:54 pm
I believe all 99 up Fords have drivers side pinions. Be careful though that the truck has a 60 in it as Ford uses Dana 50's as well. I think the moonlight truck uses a regular frame, but it may have lots of boxing or it might be stock I don't know. I hear Terry the owner is a nice guy I am sure you can contact him and find out.
Return to Competition
