dyno numbers
Re: dyno numbers
Postby gear jammer 91" » Thu Apr 29, 2010 5:22 pm
I would hope 100 psi would be enough. The ideal drive pressure is 1:1. I think it would be easier to monitor your drive pressure, if your d/p gauge is the same psi as your boost gauge. That way you could tell at a glance if your d/p is higher than your b/p. What's the exhaust outlet size on your exhaust housing? On the 40's it's 4", I believe that it's only 3" on the after market exhaust housings. If that is the case, I would think that the 5mm exhaust turbine size difference, plus the 1" exhaust outlet difference would add up to a noticeable d/p, and egt drop.
01 LB7
gear jammer 91"
Re: dyno numbers
Postby pulltilbroke » Thu Apr 29, 2010 5:38 pm
yep 3" outlet, I kinda lookin around a turbos right now. I'm thinkin a 62/71/.70 would work out pretty good and leave me ith a little room the grow.
Re: dyno numbers
Postby SNOOT » Thu Apr 29, 2010 6:21 pm
pulltilbroke wrote:yep 3" outlet, I kinda lookin around a turbos right now. I'm thinkin a 62/71/.70 would work out pretty good and leave me ith a little room the grow.
.70 is small I used a .84 for some time still made pretty good heat with it. The one I used for over a year was a 1.0 and now its working good with the twins.
1993 W350
SNOOT
Re: dyno numbers
Postby Richie O » Thu Apr 29, 2010 6:32 pm
Borge Warner told me the .80 ar was a 14.77 cm housing. I think anything smaller then that is to small. I want a good flow at high rpm's. I am scared of the 12cm's. :D
Re: dyno numbers
Postby oldestof11 » Sat May 01, 2010 8:00 am
WTF????
NO ONE SAW THIS?!?!?!
Stomp did 7xx at May madness YESTERDAY! No. 2 only!!!
:twisted: :twisted: :twisted: :twisted:
Re: dyno numbers
Postby bgilbert » Sat May 01, 2010 8:08 am
oldestof11 wrote:WTF????
Haha even without a video, pic or dyno sheet it doesn't take long for things to get all turned around. :lol: For all we know it never happened :lol: :lol: ;) .
Bill Gilbert
bgilbert
Re: dyno numbers
Postby soggy » Sat May 01, 2010 12:14 pm
We know for sure it wasn't on diesel only, plus he's being a dunderhead and not showing any proof.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Re: dyno numbers
Postby slowdiesel » Sun May 02, 2010 4:29 am
Maybe we should change your name to salty,LOL,JK. I think it happened!! And i am think it could not have happened to a nicer guy! We should just all be happy to see numbers out of a VE like that. I know it puts a little fire under my ass and we all need that sometimes.
1984 D100 Ve-Twins.
Special Thanks Mayer Farm Equipment
slowdiesel
Re: dyno numbers
Postby RSWORDS » Sun May 02, 2010 7:45 am
Video Here: YouTube - My Movie
RSWORDS
Re: dyno numbers
Postby meby » Sun May 02, 2010 9:25 am
Congrats Stomp. I just saw this over at tdr and thought I should come over here to see if this was for real. 8)
Is it for real Stomp? 700hp on #2 only?
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: dyno numbers
Postby KTA » Mon May 03, 2010 7:23 am
Glad to see Stomp is back about where he was on power. We have discussed before how easy it would be to do over 700 at May Madness since they typicaly have a 12-15% correction factor. I don't know what it was that day but I am sure it was substantial. I am glad to see a VE laying the smack down at a big event none the less.
Re: dyno numbers
Postby RSWORDS » Mon May 03, 2010 2:24 pm
KTA wrote:Glad to see Stomp is back about where he was on power. We have discussed before how easy it would be to do over 700 at May Madness since they typicaly have a 12-15% correction factor. I don't know what it was that day but I am sure it was substantial. I am glad to see a VE laying the smack down at a big event none the less.
It was only 5% that day
647.31 on #2 and 707.52 on water/nitrous
RSWORDS
Re: dyno numbers
Postby KTA » Mon May 03, 2010 4:22 pm
So that is like 615 #2 only uncorrected. Without a doubt the most powerful currently running VE truck on the planet!
Re: dyno numbers
Postby RSWORDS » Mon May 03, 2010 5:28 pm
So Brian is that close enough to get you off your butt? :lol:
RSWORDS
Re: dyno numbers
Postby AHineman » Mon May 03, 2010 5:42 pm
KTA wrote:So that is like 615 #2 only uncorrected. Without a doubt the most powerful currently running VE truck on the planet!
Whats going on with Old Yellow?
Return to Competition
