dyno numbers
Re: dyno numbers
Postby 1990 » Sat Nov 20, 2010 1:23 pm
motorwood wrote:We made three runs, one with 1/8th" timing and no KSB (331hp 805tq) then two more with 1/4timing" and KSB energized (379hp 848tq, 374hp 832tq) The shop is reputable and had nothing to gain by inflating the numbers since I did my own engine work. I cant get my sheets to upload for some reason. I will as soon as I can I will. I'm gonna drag race it tomorrow, dont have high hopes trying to shift a manual truck transmission.
It seems really high for what mods you have. You have a stock turbo and lift pump!
2012 Subaru WRX TP Stage 1 DD
Re: dyno numbers
Postby motorwood » Sat Nov 20, 2010 7:10 pm
Dyno runs are relatively short, I'm sure that power level couldnt be held for long. It would suck the filter dry. Not to mention the turbo is probably overspeeding considerably. I dont know the boost level as it lays the needle against the 0 peg (which should be 40psi) and holds it there. I twisted the transmission input shaft off at the drags today.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: dyno numbers
Postby KTA » Sat Nov 20, 2010 8:53 pm
Sounds like you must have a good clutch!
Re: dyno numbers
Postby motorwood » Sun Nov 21, 2010 2:11 pm
Yeah, Kennys Pulling Parts put together a fine piece. My stupidity broke the trans.
motorwood
Re: dyno numbers
Postby 91_bas_cummins » Mon Feb 28, 2011 11:17 pm
I went to scheids diesel. My truck would not shut off, so I had them make some upgrades since I took the trip.
I told them I want to max it out (and keep it looking stock) but be able to drive and tow with it.
So they "maxed out the pump" But what they did I have no clue.
I also had them put in the biggest injectors they had, a 14mm turbo housing, a larger exaust manifold, and give it a tune up (adjust the valves I think).
I put a K&N air filter in it.
I had them run it on their dyno when I picked it up.
280 rwhp, 1000 ft-lb torque, is governed at about 4,000 rpm, and makes about 38 lb of boost
I would like to see a dyno chart for it tho.
It has 4.10 gears, a 5 speed manual, on 10.50 x 33
Does any one know why I have a bunch of torque and not as much increase in HP?
I think the coolest thing is (that besides the smaller turbo housing and exaust manifold) it looks bone stock (and they look close).
Any other suggestions are welcome.
91' 1st gen 12V
280 hp / 1000 ft-lb
91_bas_cummins
Re: dyno numbers
Postby 1STGENFARMBOY » Tue Mar 01, 2011 7:51 am
I would run it on another dyno before i took those numbers to the bank..
normally the torque is double the horse or there abouts....that is an extreemly big gap.
this is just my thinking. and nobody ever said i was the sharpest knife in the drawer.
Dar
Re: dyno numbers
Postby 91_bas_cummins » Tue Mar 01, 2011 10:17 am
That is what I thought.
Can any one else possibly explain my numbers?
91' 1st gen 12V
280 hp / 1000 ft-lb
91_bas_cummins
Re: dyno numbers
Postby KTA » Tue Mar 01, 2011 10:58 am
With my stock turbo on old yellow on Scheids mustang I made 287rwhp and 1000ftlbs of torque. At that time they did not use an rpm pickup on the engine, and the ratios they had plugged in the computer were incorrect for my truck and thus it showed the power occuring at a lower rpm than it really was so therefore the torque values were to high. I am guessing the same thing probably happened with you.
Re: dyno numbers
Postby 91_bas_cummins » Tue Mar 01, 2011 1:29 pm
So 1. I should probably get redynoed.
and 2. What do you think my numbers should be?
My truck is not lacking power that for sure, and the low gears are sweet.
Plus if I go with any more mods I am going to have to stud the block, and I dont want to get into that right now.
91' 1st gen 12V
280 hp / 1000 ft-lb
91_bas_cummins
Re: dyno numbers
Postby GLHS » Tue Mar 01, 2011 6:40 pm
91_bas_cummins wrote:......................................Plus if I go with any more mods I am going to have to stud the block, and I dont want to get into that right now.
Why would you need to stud the block?
GLHS
Re: dyno numbers
Postby 91_bas_cummins » Tue Mar 01, 2011 10:14 pm
Well with all that pressure (the fuel and the 38 lbs of boost),
the motor can not take to much more.
Believe it or not.
When it was on the dyno and under full load
It actually started to leak a bit of anti-freeze by the head
Because the head was being pushed apart from the block.
So if I do any more modes I should probably stud it to hold
the head down better.
The good news is that as soon as they left off the leak stopped
And it has not been a problem.
91' 1st gen 12V
280 hp / 1000 ft-lb
91_bas_cummins
Re: dyno numbers
Postby soggy » Wed Mar 02, 2011 8:07 am
Have you re-torqued your head bolts?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Re: dyno numbers
Postby 91_bas_cummins » Wed Mar 02, 2011 11:16 am
What should they be torqued to?
91' 1st gen 12V
280 hp / 1000 ft-lb
91_bas_cummins
Re: dyno numbers
Postby KTA » Wed Mar 02, 2011 2:30 pm
There is no need to redyno unless you just want a number that you can brag about. The Hp number will be correct, only the torque number will be wrong.
Re: dyno numbers
Postby Cnp22 » Tue Mar 29, 2011 3:16 pm
91_bas_cummins wrote:What should they be torqued to?
If I were you I'd change the head gasket and retourqe the head bolts to 130fttq or so.
1992 auto, pump mods, 5x16's, 66/74, 8.9 1/8th
1992 getrag, p-pump, 540hp 1300fttq, 8.4 1/8th, 13.2 1/4
Cnp22
Return to Competition
