dyno numbers
Re: dyno numbers
Postby motorwood » Sun May 08, 2011 6:31 am
383/869 had to put the 12mm back on
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: dyno numbers
Postby fatty » Sun May 08, 2011 3:02 pm
I just did 283/512 with pump maxed, 366, ground stock cone, 62/65/12, stock auto trans, stock injectors.
Re: dyno numbers
Postby motorwood » Tue Jun 14, 2011 7:34 pm
454/1080
motorwood
Re: dyno numbers
Postby soggy » Tue Jun 14, 2011 10:39 pm
motorwood wrote:454/1080
Nice numbers! Got a dyno graph? Same setup as in your sig?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Re: dyno numbers
Postby motorwood » Fri Jun 17, 2011 5:38 am
dyno sheet :D
motorwood
Re: dyno numbers
Postby 1STGENFARMBOY » Fri Jun 17, 2011 6:21 am
Good Lord Buster those are some impresive numbers. :shock:
Darwin
Re: dyno numbers
Postby gobigorgohome » Sun Jun 19, 2011 1:00 am
173 hp here today at abput 65 oustide an 50-75% humidity kimda upset about it. i was hopin for 200 but i guess it will have to wait till next time :)
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Re: dyno numbers
Postby JQmile » Thu Oct 06, 2011 2:17 pm
447 on fuel, 854 on spray :mrgreen:
JQmile
Re: dyno numbers
Postby Richie O » Sat Oct 15, 2011 11:36 am
My 93
Just ran 302 and 720. Same set up as last year as far as fuel, timing ect. Only change was the 62/71/14 HTT that replaced the 16cm 60mm gds H1C. I was up about 20 horses from last year. My first run 3 years back was 301 with the skinny 235 85 16's, then it went down to 282 ish when I put the bigger 17 inch tires on, and now I gained the 20 back with the new turbo. Pretty happy. She pulled good, still got 1500 egt on the dyno and ran about 47 to 48 psi.
Re: dyno numbers
Postby 1STGENFARMBOY » Mon Oct 24, 2011 10:38 am
Man Richie i would have figgered more than 20 with the new turbo, your happy, i'm disapointed. :lol:
Dar
Re: dyno numbers
Postby Richie O » Mon Oct 24, 2011 1:16 pm
1STGENFARMBOY wrote:Man Richie i would have figgered more than 20 with the new turbo, your happy, i'm disapointed. :lol:
Dar
Well, I was surprised it made that much difference. I didn't add fuel, and the old turbo cleaned it up well, just was super hot doing it. This turbo is cooler, but still plenty hot. For anyone who is afraid of getting a 62/71/14 because they are not friendly towing, or street driving, don't worry. They drive fine. At my hp and timing it is very drivable.
Re: dyno numbers
Postby motorwood » Tue Oct 25, 2011 12:49 pm
A disappointing 437/857 at Mason Dixon TDC's Fall Brawl.
motorwood
Re: dyno numbers
Postby KTA » Wed Oct 26, 2011 1:04 pm
That 66x74 turbo is to big. A 62x71 would have been a better choice. I am guessing by your torque loss that your power was made higher up than before.
Re: dyno numbers
Postby motorwood » Wed Oct 26, 2011 1:20 pm
I'm sure your're right(my print out gave mph only), and no AFC doesnt help either. It was an inertia only dyno, larger tires, 5th gear vs 4th. I'm curious to run it some time on the same dyno that netted the 454/1080.
motorwood
Re: dyno numbers
Postby BC847 » Sat Oct 29, 2011 2:12 pm
489/845. 0 correction, 12mm VE, fuel only.
It should have had higher torque IMO but the dyno operator starts the run way too late.
Return to Competition
