dyno numbers
Re: dyno numbers
Postby FourSpeedSteve » Fri Aug 31, 2012 8:58 am
I wanted to see that other truck, as I heard it was nice from what people saw of it pulling in. I just wasn't up for paying extra to get into the dragstrip. They need to work out a deal on the tickets to include dragstrip entrance next year.
Thanks for the G56 link, I'll check it out.
I also want to do something with either the wheels, or the tires on my truck. Possibly either have the stock wheels widened to 8" to better fit the 285/75's or go to a 255/85 on the stock 6" wheels. I bought the truck with these tires on it, and like them, but am not sold on the "285 squeezed onto a 6" wheel" look...lol
91.5 W250 LE reg cab, Getrag 5spd, 4.10 posi, everything but cruise, 4" DE exhaust, 5x.013 Scheid Lightnings, HX35/16cm W/G from a '95, Autometer boost & pyro.
Other toys: bought new 96 Dakota with 390 stroker, 80 IH Scout Traveller with factory Nissan SD33 turbo/IC 6cyl diesel
FourSpeedSteve
Re:
Postby cummins12club » Mon Sep 03, 2012 8:34 pm
JAyers wrote:Scheid diesel extravaganza
422hp/834ft lbs at 38psi. #2 Only.
93 250 4x4, 5speed, Autometer Pyro, Tach, & boost, 7in miter, pump maxed, SPS62, BIG edm's or DDP 3's, 3200 gsk, ASA intake, Lots of head work, Studs, piston lift pump, H2 Cam.
???? what color is ur truck i dynod mine at terra haute on friday it was black ext cab first gen if u saw it on schieds dyno i only made 200hp 577lbs torque, upset that i missed ur truck
cummins12club
Re: dyno numbers
Postby BC847 » Mon Sep 03, 2012 8:48 pm
You do realize that JAyers made that post on: Sun Aug 26, 2007?
viewtopic.php?f=25&t=961&p=6981#p6981
:D
Re: dyno numbers
Postby cody 85 » Mon Oct 01, 2012 5:12 pm
312HP pump tweaked, M&H timing spacer, ground fuel pin, stock air box, stock exhaust no muffler. 91 none intercooled. Stock turbo ex housing.
i was really surprised to see that number.
cody 85
Re: dyno numbers
Postby cmann250 » Mon Oct 01, 2012 5:22 pm
cody 85 wrote:312HP pump tweaked, M&H timing spacer, ground fuel pin, stock air box, stock exhaust no muffler. 91 none intercooled. Stock turbo ex housing.
Stock injectors and 60mm compressor upgrade? Them's nice numbers
Re: dyno numbers
Postby oldestof11 » Mon Oct 01, 2012 5:53 pm
Alligator dyno day? O thought i saw your name.
Re: dyno numbers
Postby Richie O » Tue Oct 30, 2012 2:01 pm
My 93 just ran 304 and 732 again. Same as last year. :lol:
Re: dyno numbers
Postby cummins12club » Thu Dec 06, 2012 9:58 pm
BC847 wrote:You do realize that JAyers made that post on: Sun Aug 26, 2007?
http://1stgen.org/viewtopic.php?f=25&t=961&p=6981#p6981
:D
I actually realized that right after I posted it lol felt pretty dumb
cummins12club
Re: dyno numbers
Postby cummins12club » Thu Dec 20, 2012 9:17 pm
JBradley500 wrote:yep i went friday from about 10-5... i saw FourSpeedSteve then i saw Tim Worline and Bill Gilbert camping but didnt see you or anyone else.
I spoke to u their when ur truck was in the show and shine I watched u dyno I too dynod mine it was the black ext cab w the cowl hood if u saw
cummins12club
Re: dyno numbers
Postby 12vsuburban » Tue Jan 01, 2013 6:56 pm
What kind of TQ did you make? stock injectors as well?
Hans
'92 one ton,auto, 250k,flatbed,original paint: WH1C turbo from a '94(12/56), BHAF, 4" exh from firewall back, fuel screw to the collar, turned stock pin
12vsuburban
Re: dyno numbers
Postby TX1GEN » Tue Jan 15, 2013 10:56 am
just dyno'd this weekend at lonestar dyno in spring branch, made 365hp/925ft lbs.
on just pump tune and hunid horse PODs.
'93 dually single cab 2wd 4" TBE, POD injectors 4x14, airdog II 165, 365hp/925ft lbs
TX1GEN
Re: dyno numbers
Postby Sutter1stgen » Thu Jan 17, 2013 10:24 am
Nice numbers! Right on.
Eric
Sutter1stgen
Re: dyno numbers
Postby quickie70 » Mon Mar 11, 2013 7:47 pm
dynoed on saturday. 306/598. Boost was down about 4psi and found the wastegate tube blown in pieces after (it normally runs 35 psi, was only 31 for the pull, some obvious leakage so the numbers are a little low, I'd guess I'm 20 low on HP and 30 TQ), only pulling to 3200 RPM (no valve springs yet) on a dynojet, uncorrected at 5300'. I'm happy with stock HPCR numbers with my setup. Never seen 1200* on the EGT and it cleans up really nicely as soon as the turbo lights. It's my driver/tow rig and gets low 20's for mileage empty and high teens towing my open car trailer and race car. Looking at others here, I think I might add water/meth and a 60mm wheel and call it a day. And for a driver, the WH1C/HX35 is a sweet street snail.
1991.5 RCLB 4x4 LE Rag w/ 3.54's 200,000+ miles, original denny T, WH1C, P/S I/C with coolertubz, pump turned up slightly, DDP stage 1's, gauges (lots of em). Custom Anti-Rusting-undercarriage 15/40 coating provided by leaky timing cover. 306 HP / 599 TQ.
quickie70
Re: dyno numbers
Postby cmann250 » Sat Mar 30, 2013 2:49 pm
Best of 274/503 today.
- Typical VE stuff (3200 spring, fuel screw pretty far in, stock pin rotated to the deep side)
- 2nd gen intercooler (originally non-intercooled)
- HX35
- Cummins low pressure piston lift pump
- 260k mile 727 (original according to the previous owner who put 230k on it)
Hasn't melted or exploded :mrgreen:
Re: dyno numbers
Postby Hansen01 » Sun Mar 31, 2013 8:03 pm
Not bad for having a 727 behind it 8)
Under construction...
Hansen01
Return to Competition
