Fast ve pump trucks....
Postby Cnp22 » Mon Mar 21, 2011 9:03 am
Just looking to see what the ve truck are running. Who's the fastest? If there is already a thread started please point me to it. Post up your 1/8th 1/4 times 2wd or 4wd? Auto or manual? Mods?
1992 auto, pump mods, 5x16's, 66/74, 8.9 1/8th
1992 getrag, p-pump, 540hp 1300fttq, 8.4 1/8th, 13.2 1/4
Cnp22
Re: Fast ve pump trucks....
Postby KTA » Mon Mar 21, 2011 5:49 pm
I am one of the fastest, but there are lots of them that are quicker.
Postby dazedandconfused » Mon Mar 21, 2011 6:38 pm
That nova runs mid 11's.
Postby BC847 » Mon Mar 21, 2011 7:28 pm
My mess is fairly quick for what it is.
'93 W250 Clubcab @ 6400lbs. 12mm VE, 6x.016 EDMs, S362/HT3B, A518
At 15' elevation (10/22/10):
1.69 60'
5.09 330'
8.01 1/8 @ 83.44
12.81 1/4 @ 101.11
Postby Cnp22 » Mon Mar 21, 2011 9:14 pm
That's pretty quick! Forgot to add my time I ran a 8.9 at 76mph last Sunday my mods are pump tunning, 5x16's, CAT turbo 66/74 all thru a stock rebuilt auto that has around 7,000 miles on the rebuild.
Cnp22
Postby ahale2772 » Thu Mar 24, 2011 6:20 am
66/74....YIKES thats a biggin
Postby Cnp22 » Thu Mar 24, 2011 2:00 pm
It's pretty big but it lites up awsome.
Cnp22
Postby BC847 » Thu Mar 24, 2011 3:27 pm
How long did the blue paint last? :mrgreen:
Postby Cnp22 » Thu Mar 24, 2011 4:25 pm
BC847 wrote:How long did the blue paint last? :mrgreen:
About 5 mins lol it was a spare one I had laying a round I was slowly porting it out and I painted it to keep it from rusting while it was on the shelf.
Cnp22
Postby ciamcoop » Fri Mar 25, 2011 4:48 am
6400 lbs? I'm wondering what I have buried in my toolbox now. With a 1/4 tank of fuel, my 80 lb lab, my 4 year old and me I weighed 7380 lbs. Thought it looked like it's been riding low..... that must be why I'm not running 13's
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Postby c12h26 » Fri Mar 25, 2011 6:58 pm
My quickest et is 12.56@106. that was with 3.07 rear 727 trans and he351ve,over the winter i put in a rebuilt 518, 3.54 rear, and a HX52.I hope to run in the high 11s with this setup. truck only weighs 4700 with me in it
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby Cnp22 » Fri Mar 25, 2011 11:27 pm
Thats a good time! How much are you spraying?
Cnp22
Postby c12h26 » Sat Mar 26, 2011 4:59 am
.125 jet
c12h26
Postby JQmile » Sat Mar 26, 2011 9:45 am
SO far I'm fast, but not quick.....10.28@82.3mph in the 1/8th. Couldn't spool/no traction. 2.96 60ft. Going back soon with nitrous and slicks :mrgreen: According to the weight/hp of my truck, mid to high 11s should be possible on nitrous, it's just that getting there is another matter.
JQmile
Postby Cnp22 » Sat Mar 26, 2011 12:58 pm
Traction is key! I ran a 9.3 with stock everything but Pump tuning and 5x16's on some old farm tires and a 9.1 on slicks. If you can get off the line good and get about a 1.8 60' time mid 8's shouldn't be a problem high 11's in the 1/4. I ran the 8.9 with a 2.1 60' time and a .445 reaction time and I'm in a heavier truck with half the power. Get some good slicks and you'll be set!
Cnp22
Return to Competition
Users browsing this forum: No registered users and 75 guests
