Fast ve pump trucks....
Re: Fast ve pump trucks....
Postby SNOOT » Mon Jun 06, 2011 10:01 am
From last weekend..
1993 W350
SNOOT
Postby 1STGENFARMBOY » Mon Jun 06, 2011 10:43 am
Snoot thats impresive for a 4x4 barge.
shoot a little W/M and you could be in the low 13's easy.
Dar
Postby SNOOT » Mon Jun 06, 2011 11:32 am
The truck next to me ran a 13.315 @ 100mph.... It was a cool little ride.. He made it into the 12's but broke a flex-plate on his 4th run..
1993 W350
SNOOT
Postby dazedandconfused » Mon Jun 06, 2011 5:41 pm
Nice little Dakota.
Postby PToombs » Mon Jun 06, 2011 5:44 pm
Twins on a 4 banger, wow! 8)
Postby RATROD92 » Sun Jul 03, 2011 11:19 am
I Just ran a 14.45 @ 111.69....
60' 2.57
330 6.87
1/8 9.89 @ 84.67
1000' 12.40
1/4 14.45 @ 111.69
Frickin 5 speed...leaving spinning both passenger 32" tall tires.black smoke...no boost until half way into third gear...smoke clears up a little boost hits 40 lbs... 4th gear pyro hits 1600* boost hits 45lbs shift to 5th pyro climbs past 1600 gauge is pegged but only for a couple seconds....boosts sticks at 45lbs ...run is over....I am ordering a 48 RE on Tuesday.
#5 cylinder is blowing smoke out where the exhaust manifold joins the head....Bolts are as tight as I can get em...letting it cool now going to throw a new gasket in it...
James
92 D350 shortened 2 feet, 56 Ford F100 Cab, VE Pump maxed 12mm, Denny II, PDI exhaust manifold, Silver Bullet 64/74/14, SCHEID 6X.016's, 5 speed Getrag, 400 horse clutch, 3.54:1 rear, Air Dog II 165, Aluminum Radiator, Pump to head, 3800 R.P.M. spring...Puts a smile on my face when its lit....
RATROD92
Postby dazedandconfused » Sun Jul 03, 2011 8:42 pm
Any idea what your truck weighs?
Postby RATROD92 » Mon Jul 04, 2011 8:23 pm
dazedandconfused wrote:Any idea what your truck weighs?
I was doing the math...I think it weighs about 3800 with me in it :D about 800 lbs for the cab, glass, fenders, grill and hood.....the rest is just a motor, trans, chassis,...it is a dually...No bed!
James
RATROD92
Postby oldestof11 » Mon Jul 04, 2011 9:03 pm
Is it gutted?
My Ext Cab, 4x4, with natural weight reduction, and 500lbs of tractor weights weighed in at 6200lbs.
Postby dazedandconfused » Tue Jul 05, 2011 3:47 am
I was figuring close to 4500 pounds. With your trap speed I'd say it's between 400-450Hp to the wheels depending on weight.
Postby RATROD92 » Tue Jul 05, 2011 4:25 am
dazedandconfused wrote:I was figuring close to 4500 pounds. With your trap speed I'd say it's between 400-450Hp to the wheels depending on weight.
I did have it towed home when I put the radiator into the fan a couple months ago....and when it came off the trailer the guy looked at me and said...." It's heavier than you think" So maybe I'm hoping 3800.00 Ok let me know if I'm missing something
Grill/lights 100
Inter cooler/radiator/fluids/ 100
hood and fenders 150
glass and cab 700
motor and trans 1300
front end and wheels 500
frame 200
dana 70 and 4 wheels/tires 600
How much more?
James
RATROD92
Postby dazedandconfused » Tue Jul 05, 2011 6:02 am
I'd think it's closer to 4500 still.
Postby mathews8pt » Tue Jul 05, 2011 6:08 am
My 93 2wd 5spd with no tailgate weighs about 5000#s with 1/4tank of fuel and no driver. There is some weight to be lost though.
2000 p-pumped 24v daily driver
1993 D250, 2wd, 5spd(for now), timed to head, hx35, PODs, electric fuel pump, ground pin. The new project truck...
mathews8pt
Postby Tacoclaw » Tue Jul 05, 2011 5:05 pm
Just the engine alone weighs almost 1100lbs, let alone that cast iron pig of a trans. I couldn't believe how much heavier my 'Rag was than my 727. I think my truck picked up 250# from just the trans swap. :sad:
Return to Competition
