Dyno Baseline...
Dyno Baseline...
Postby blk_smoke » Mon May 16, 2011 5:33 pm
So I went to the TNE Diesel all Diesel Truck Dyno Day to get a baseline on the ol truck.
after a few runs i got 185hp and 443ft/lbs of torque. not bad for just haveing the pump maxed out and a 3200 spring.
unfortunatly I did however burst the fuel solenoid and now the truck wont shut off by key... this happen to anyone else?
92' d250 Cummins 2wd, 47rh
blk_smoke
Re: Dyno Baseline...
Postby Tacoclaw » Mon May 16, 2011 5:50 pm
It's apparently a pretty common thing to have happen, with a turned up pump anyways.
Probably shouldn't make a habit of chipping them up, as they can clog up your DVs. I'd say convert to the cable shut-off club if you gotta keep your pump maxed, or grab some injectors and back the pump off some to make life easier on the poor plunger.
Postby BC847 » Mon May 16, 2011 8:53 pm
Running larger injectors will fix that. If you're into it. ;)
Postby ciamcoop » Wed May 25, 2011 1:59 am
Pull cable is the only way to go, great theft deterrent too.
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
ciamcoop
Postby gobigorgohome » Fri Jun 17, 2011 6:18 am
man, after seein them numbers it makes me think that morrow on the rollers ill be at somethin like 150 to the wheels :shock: ive just got the pin ground some an the power screw in a turn, star wheel down 3 and smoke scrw flush. course stock injectors an no i/c. what yall think this combo will do?
91 4x4 with the 727, has the factory tach!
Boost gauge installed 27psi, new exhaust manifold here just not on yet. Pyro installed all glowshift units. 173 HP baseline before poor mans 4 inch dp
gobigorgohome
Return to Competition
